Hot Rods I Can Fabricate Fairly Well . . . but I envy the guys with Sheetmetal skills!
Discussion in 'The Hokey Ass Message Board' started by Bored&Stroked, Apr 25, 2010.
  1. Yah know . . . just spent the better part of Sunday completing a set of early Hemi motor mounts for my 34 coupe. When I was done, I really liked the work -just made me happy to see my "metal sculpture" results . . . felt good. I realize that over the last few years, that I've grown comfortable making just about any frame piece, suspension setup, custom mount, bracket, hairpins, etc.. -- it is all just "clay" in my hands. I'm not afraid to make dang near anything . . . to create what I see in my head, out of steel.
    Completed Mounts:
    BUT - I am totally envious every time I see somebody take a piece of raw sheet metal and form a fender, build a body panel, etc.. I see the sculptures created by great coach builders and I hope that some day I can acquire those skills as well. I don't fear it . . . just hope that I have time to learn that part of the hotrod building spectrum. I keep thinking about how many tools I'll need to head down this path --> English wheel?, Power Hammer, Shrinker, Stretcher . . . the list in my head goes on.
    Someday boys . . . if I live long enough, I'll learn to shape sheet metal . . . until then, I guess I'll just continue to be in awe and keep dreaming of the day I'll start this journey.
    To those of you with the skills -- I totally respect the time and work that it took you to learn them . . . I salute you for your accomplishments.
    So much to learn . . . and so little time :rolleyes:
  2. Hmmm . . . picture didn't show . . . here is today's accomplishment:
  3. AAFD
    AAFD
    from US of A
    Nice mounts. Check out MetalMeet.com
  4. HemiRambler
    HemiRambler
    I'd bet you're closer than you think.
  5. hotrod1940
    hotrod1940
    Yeah, i'm betting on you making a great sheet metal worker. The mounts are fantastic. Not often you can say that amount something as simple as a mount.
  6. AAFD
    AAFD
    from US of A
    Before you dive into buying expensive metalshaping equipment, let me suggest a few things...
    First, do some research on what you want to learn. There are literally TONS of videos on youtube each with various ways of acheiving the same result. There are tons of build threads and tech threads on the HAMB that really show you how to do something or show you a simpler method of doing what you've been doing the hard way. There really is alot of talent here. That link I sent you to "Metal Meet" is another good source of information, and there are others on the web. There are also alot of books that have alot of good information, but for me, watching it happen on video, or having an in-depth explanation on the internet is easier, more like you're there in person.
    Second, use what you have laying around. Apply what you have watched or read up on, and give it a go. There are alot of ways to make the same piece with simple hand tools that a big fancy expensive machine will do...it's actually quite amazing. Remember, these machines and equipment came AFTER the hand methods of shaping. You'd be surprised what a dull chisel and a ball peen hammer can create with a piece of sheetmetal. Same goes for a tree stump and a baseball bat, or some s**** metal and an idea for a tool.
    Third, be patient. Shaping metal is not for the lazy or unwilling to fail. You will fail, over and over again, but you will learn from your mistakes and you will eventually hone a skill that few on this earth posess. You can purchase and make your own equipment while you learn the different techniques, and find out what kind of equipment you would need and find out what you dont need. I've seen far too many english wheels and planishing hammers collecting dust because the owner did not want to invest the TIME it takes to learn how to use the tool. The possibilities are unlimited, give it a go and good luck!
  7. hotcoupe
    hotcoupe
    great looking motor mounts! there are only a few things that you can do with a piece of sheet metal. you can cut it, weld it, stretch it, and shrink it and i`ll bet you already know how to do at least three of the four. that is a paraphrase of something that ron covell said in a sheet metal forming cl*** that i took several years ago. take advantage of the sources that are available, metalmeet.com is one that`s at the top of my list.
  8. Kona Cruisers
    Kona Cruisers
    Take a sheet metal cl***.... Priceless
  9. jhnarial
    jhnarial
    from MISSOURI
    You don't need a a ton of tools to shape some metal.
    I hate when someone says I'm going to start as soon as I buy a pulmax.
    That's bullsh--.
    I'm not saying that is what you are saying but I have heard it a lot.
    I will help you with some of the basics but it will cost you. If I give you advice on how do something you owe a picture thread of your attempt.
    I do have to warn you this is a very addictive hobby and it is not for the weak hearted.
  10. Appreciate all the replies . . . helps me keep the perspective and want to expand my skills in this area (sooner than later). As noted - one doesn't need all the heavy-duty 'production' tools that we'd all love to have, but can't afford to own for personal work.
    I'm always looking to get better -- thanks for the encouragement!
  11. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Start with a few basic hand tools like a couple of blocking hammers, some snips, a ******* and a bag. Don't but anything in a " KIT " these kits usually contain marginally useful " tools " and maybe one or two necessary ones! Most of the necessary hand tools can be made by you from cheap material.
    " Real" english wheels, Yoder power hammers, CP planishing hammers, Pull Maxes and kick shrinkers all are big money these days, and take up a large "footprint" in your shop. Their isn't anything these pieces of equipment can do that you can't do with basic hand tools, they only produce results quicker.
    '' Do not reach greedily for the Kool-Aid ''
  12. Thrillbilly
    Thrillbilly
    from Joplin,MO
    In the beginning power tools will only let you make mistakes faster !
  13. dabirdguy
    dabirdguy
  14. smiffy6four
    smiffy6four
    Thanks for the links, I just signed up for allmetalshaping Cool site!:)
  15. Gleeser
    Gleeser
    from Taylor, MO
    I see you're in the midwest somewhere. I live in Northeast MO. PM me sometime, I'd be happy to show you some sheetmetal stuff or put you in touch with someone close to you who'd do the same. (most likely)
    Definitely join www.allmetalshaping.com
  16. Thanks a bunch! I've been around body and paint for years -- used to paint custom and show cars out West, have done basic body work for years, just not sheet metal fabrication. Also, I have a TIG welder, have a good air compressor and plenty of tools -- just need to truly understand the basics of metal forming, stretching, shrinking, panel welding, panel straightening, etc.. Once I know more about the basics, it just becomes practice, practice, practice . . . like any other good hotrod skill.
    I'll get in touch with you later on this summer - maybe you can steer me the right direction!
  17. bobss396
    bobss396
    If you can find one. Vocational schools have them at nights once in a while. I was lucky to start tin bending in 8th grade. I later got deep into it with a tool & die course I took. Eventually I was programming Weideman and Amada presses and methodizing 2nd operation brake work.
    Pick up some basic books to learn flat pattern layout, bend allowance (or bend deduction, which still drives me crazy), and basic formulas for bend radii with respect to material thicknesses.
    You don't have to have that many tools and make friends with someone that owns a sheet metal shop.
    Bob
  18. todd_a
    todd_a
    from Tyler, TX
    Really fun stuff!!!!!!! But it will take you away from building cars while you hone skills practicing on stuff.
    I'm just a step ahead of you it appears - I just started trying to learn how to shape metal.
    Here is all you need to get started: An old Bat and a "stump" or something wood with a bowl shaped cavity in it - I used a piece of 2x6.
    This is where that "bowl" project is at at this point. Not finished, but I had to take abreak to do some work on the hot rod....
  19. continentaljohn
    continentaljohn
    Great job on the mounts they look sweet!
  20. ZRX61
    ZRX61
    from The AV
    There's always the $$$ route with Lazze or Tinmantech..
  21. John_Kelly
    John_Kelly
  22. Racewriter
    Racewriter
    I'd recommend any of Ron Covell's videos. Bought his English Wheel video at his booth at the GNRS, watched it, and now I'm forming panels for my stock car on my small $80 Harbor Freight wheel. Not show car worthy yet, but definitely good enough for this application!
  23. rustyhood
    rustyhood
    You would be amazed at what equipment you already have in your garage.
    If you have a work bench: you have a metal brake. The edges and corners are very handy in forming metal. The vise works great for short bends and shaping.
    Square tubing is great for recessing and braking metal. Its really awesome to have someone think you bought a part you made by hand. Keep at it, your mounts look store bought. Good job!
  24. Hey Gang: Thanks for all the encouragement -- I like all the input, ideas and positive at***udes. It was this same type of thinking and desire that got me started on heavy-duty fabrication and TIG welding --> if another man can do it, you can.
  25. haroldd1963
    haroldd1963
    from Peru, IL
    Great info here!
  26. Pat Pryor
    Pat Pryor
    heres my practice . i didnt do much sheet metal shaping befor this. hammerd out a few gas tanks when i was 15 but thats it. go for it, it's addicting and a lot of fun.
  27. Yeah I love that handmade coupe. Those motor mounts kick *** dude!
