Silly C4 Question?
Discussion in 'The Hokey Ass Message Board' started by gaskell, Apr 30, 2010.
  1. gaskell
    gaskell
    from CO
    OK
    Have a C4 Trans.
    What is the shift pattern when moving the shift lever?
    Front of car P-R-N-D-2-1 Back of car
    Front of car 1-2-D-N-R-P Back of car
    Thanks in advance and sorry for the silly question.
    -LarryG
  2. Maco-B
    Maco-B
    The factory shifter is p-r-n-d-2-1. If your doing your own. The best I can suggest is to move the linkage into park. Which on a C-4 is all the way down towards the floor. The front rod (nearest the engine) is for the shifter.The rear is for the kickdown / p***ing gear , that hooks up to your carb.
  3. gaskell
    gaskell
    from CO
    Thanks.. Just to clarify... If I grab the lever on the side of the transmission and the move it all the way to the front of the car this is Park? Or is this 1st?
  4. RQuantz
    RQuantz
    from Las Vegas
    Can't remember what the side of the transmission looks like, so I can't help you too much on the linkages. If you need more help, let me know and i'll crawl under my Mustang and investigate.
  5. shinysideup
    shinysideup
    from ruskin, fl
    Depends on if the shaft lever is on top or bottom.
  6. EZrider
    EZrider
    from Waco, TX
    :confused:
    SILLY is right,
    If you can't figure this one out on your own,
    you should turn in your Alliance membership.
    :mad:
    old Bob
  7. gaskell
    gaskell
    from CO
    Yah I know. So here is the story I got this F--d for my daughter. I know Mopar, I know Chevy.... Who knew Ford was so different. I figured I had a 50/50 chance. The trans is missing the shift lever but has the kick down lever. They are both on the same shaft... So far this has been all kinds of fun ;/
  8. Maco-B
    Maco-B
    The trans is missing the shift lever but has the kick down lever. They are both on the same shaft... So far this has been all kinds of fun ;/[/QUOTE]
    Take a pliers and click the inner part of the shaft "up". As far as you can. once you can go no further, and the trans feels in gear....then put a channel locks on the tail shaft. I she does'nt move, You've found Park. Work from there.
  9. RidgeRunner
    RidgeRunner
    from Western MA
    On the earlier [60's] C-4 we are working with: With the lever on the transmission pointed up; to the rear park, next forward reverse, then neutral. Have put in a manual reverse valve body so from there forward goes 1-2-3, otherwise stock would have been drive,2,1 [most forwared].
    Ed
  10. gaskell
    gaskell
    from CO
    Everyone, Thanks for the help... got it now.
    Learned mucho.
