Who makes a decent gas pedal asembly????
Discussion in 'The Hokey Ass Message Board' started by Double Caddy, May 1, 2010.
  1. Double Caddy
    Double Caddy
    from virginia
    I am moving the master cylinder from the fram to the firewall. The brake pedal is moved from the right side of the steering collum to the left which means the gas pedal will be a good 8 inches away at least so I will need to put on a new gas pedal ***embly with a cable setup . I dont need anything fancy . I just want something that works. Any suggestions on suppliers. I am looking for a kit that I dont need to buy anything else to make it work. This should be my last hurdle for me to get the car on the road.
  2. cwayne
    cwayne
    I use LoKar a lot but they do cost a little more... try summit on line they handle a few gas pedals that don't cost an arm and a leg...
  3. 63FalconFutura
    63FalconFutura
    from Socal
    i believe moon sells a chrome foot pedal :p
  4. Moon? Hotrod parts? Never!:rolleyes:
  5. fab32
    fab32
    If you have any hot rod cells in your blood stream head to the local wrecking yard and pull a unit from a late model wreck. Most are very simple in design and are cable operated. Shouldn't take more than an hour to locate and pull one.
    Frank
  6. Ter409
    Ter409
    from NE Oregon
    I have used Chev PU gas pedals on a couple of my projects. Not a bolt-in, you do have to make some mods but they are cheap and making them fit is the game. Ter409
  7. caddy-man
    caddy-man
  8. Check out a wrecked Camry ;)
  9. haroldd1963
    haroldd1963
    from Peru, IL
  10. john walker
    john walker
    yes indeed. i used one of those on my diamond t and it works great. along with a lokar cable of course.
  11. Double Caddy
    Double Caddy
    from virginia
    Thank you all for replying . This gives me a great starting point. I will let you know what I end up with.
    Todd
  12. I got a gas pedal (or as my late father called it, a "foot feed") from an '80s vintage Camaro, took the plastic pedal pad off, cut the s**** from my '38 Ford pickup's original pedal and welded it onto the Camaro pedal arm.
  13. Johnny1290
    Johnny1290
    Is it just me that hates those Lokar gas pedals?!?
    I grabbed one from an 80's buick or something at pickapart. It's plastic and has fancy chrome around it :)
    I wanted one that was comfortable and didn't cost much, but next time maybe I'd just buy a s**** type from a catalog
  14. Mean Lean
    Mean Lean
    I think Mr. Ludwig from Chicago can help you with this...
  15. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    GM makes a good one. So do Ford and Chrysler. Toyota, not so good...
  16. 56sedandelivery
    56sedandelivery
    Everyone has pretty much covered the bases. Do you have a sense of humor? How about TOYOTA??? Ha Ha. Butch/56sedandelivery.
  17. pasadenahotrod
    pasadenahotrod
    from Texas
    The early 70s Fords all have a variation on a theme. A simple firewall mounted accelerator pedal ***embly which mounts with 2 bolts/screws.
  18. dudley32
    dudley32
    Toyota ??? Sure!! you can get in the recall.......
  19. rusted_nut
    rusted_nut
    from Arkansas
    I couldn't find one that I liked, or that would fit like I wanted, so I built my own. It's not a complicated part to fab, and mine works great.
  20. Double Caddy
    Double Caddy
    from virginia
    I ordered a lokar pedal ***embly and cable. I dont have a welder readly avaliable so this was my best option. Thanks again for all your input.
  21. thebronc4019
    thebronc4019
    from New Jersey
    Watch that Lokar unit. I used one and it was ****. each time I would reinforce the weak area on the ***embly the flex point would just move to the next area. After messing with it for 6 months I junked it and modified a GM factory unit that has worked flawlessly ever since I installed it.
  22. Chili Phil
    Chili Phil
    That made me LOL out loud..
