carb ideas
Discussion in 'HA/GR' started by sgtlethargic, Mar 29, 2010.
  1. ScottV
    ScottV
    Hmmm .... must have been a "Rat Rod" ...:p
  2. FANTASY FACTORY
    FANTASY FACTORY
    Quite the opposite, with no other changes to the valve train, stroke or bore, the signal would be so week as to caue a big fat stumble from being lean, unles he jacked the acc pumps.
    Ita amazing how many 4 bbls i correct just by disconnecting the seconaries.
  3. ThingyM
    ThingyM
    If it's the cast iron Vair box.. I don't think you can reverse that one..Just nmake it work.. Know 0, nadda, nothing about Jag carbs..Thats the idea of this cl***, Just use what ya got....
  4. quick7
    quick7
    from Tulsa OK
    I just reversed a cast iron box,same way you reverse an aluminum one.
    2ea 1 bbl holleys from an early slant 6 will work great.
