car rear in my 57 truck ?
Discussion in 'The Hokey Ass Message Board' started by 57 3100, May 3, 2010.
  1. 57 3100
    57 3100
    guys,
    in my 57 i currently am running a 1980 1/2 ton rear with 5x5 lug pattern. the overall width is 65 inches. that, and the lug pattern has limited me in my wheel width and selection. most of the wheels i like are for 5x4.750 bolt patterns out of a car.
    so my question is, what style rear housings are you guys running ? camaro, chevelle, etc ?
    i am doing my homework and have a line on a rear form a 70 chevelle that is 62 inches wide, gaining me 1.5 inches on each side, allowing me to use a deeper dish wheel of my choice.
    i want to stick with the leaf spring setup.
    just curious what you guys are running ?
    thanks much.
    leonard
  2. THE-SYNDICATE
    THE-SYNDICATE
    Mine has a '56 Chevy P***enger Car Rear for it. It measures 61" I think.
  3. little skeet
    little skeet
    from huston
    My brother has a 56 pickup, he installed an S-10 rear axle in it.
  4. bfink55
    bfink55
    from Turlock CA
    before i got my 9" ford i had an s-10 rear in my 55 , i was able to run N-50-15 tires on a 15x10 wheel (but i did have to cut the bed and mini tub it) i think camaros will work too , not sure on the with but ive see them w/15x8's
  5. 53sled
    53sled
    from KCMO
    leaf spring perches are $10 at jegs, speedway, summit.....
  6. bobkatrods
    bobkatrods
    from aledo tx
    i have a gto mid 60"s 8 inch wide wheels
  7. UnsettledParadox
    UnsettledParadox
    i put a '69 camaro rear in a '55 chevy truck. took a little welding/grinding but it worked nicely
  8. 57 3100
    57 3100
    dang dudes, thanks for the fast info.... greatly appreciated.
    i am currently stuck with a 15x7 wheel with 4.5 backspace. i want the car rear with 4.750 pattern and narrower so i can run deeper dish wheels.. i will also search for s-10 rears.... thanks again.
    leonard
  9. Deuce Roadster
    Deuce Roadster
    A 70 to 81 Camaro/Firebird rear end is 62.5 inches wide.
    The same width as a 70 Chevelle. :)
    But the Camaro/Firebird rear end is a leaf spring rear end from the factory.
    The Camaro/Firebird rear end does NOT have all the ugly brackets and such on it
    The 10 bolt ones are plentiful ... the 12 bolt ones are harder to come by.
    :D
  10. olpaul
    olpaul
    I'm running a 10 bolt from a Firebird in my 58 pickup. Works great.
  11. I'm using a 99 s10 4x4 4 door rear. It has a limited slip with disc brakes. I'm running 15x10 with n50 x 15's. I had to do small tubs but they work out ok.
    Why not try an adaptor to run the wheels you want? I ran 2.5" spacers for two years before I tubbed mine. Never much weight in the rear.
  12. tmac396
    tmac396
    I'm running a '57 Chevy p***enger car rear in my '59 Apache. Works great and my 15x10 chrome reverse wheels are perfectly centered in the fenders.
  13. 57 3100
    57 3100
    thanks much guys. i will search for the older camaro/firebird rears first, or even the s-10's, since they have the leaf mounts already. less work.
    now you guys got me wanting to mini tub it also. LOL.
    leonard
  14. J-lopy Kid
    J-lopy Kid
    Read an article, and saw one done. Took 2 short sides of a 1963 ford 9 inch. basically came up with a narrowed 9. Used 1970 inner bed wheel well parts to "tub" the back. Looked similar to the yellow bed above!
