What to pay for a guy to rebuild C4 trans?
Discussion in 'The Hokey Ass Message Board' started by fordstandard, May 3, 2010.
  1. fordstandard
    fordstandard
    I just got a 1972 C4 Transmission (for my Shoebox Ford) that I want to have rebuilt
    *Question - A friend can get me a "rebuild" kit at cost. What is fair price a mechanic should charge me to rebuild it, if i suppply the kit?
    *How many hours does it take to rebuild one?
    Thanks
  2. tcnotch
    tcnotch
    from Toxic City
    Your probally better of just having them buy the parts and doing the rebuild that way you will have a waranty. Price wise will depend on what parts are bad. Are you replacing the converter to?
  3. greaseguns
    greaseguns
    do it your self there easy
  4. Blue One
    Blue One
    from Alberta
    So tell us how.
  5. Friend here (a transmission pro) charges me $100 to ***emble a transmission plus parts.
    I take it apart and clean the components. He inspects everything which is important. Used transmissions always need something that is not in the rebuild kit.
  6. bobss396
    bobss396
    I've always been able to find a shop that'll take a loose transmission and rebuild it for me. Look for an older shop, not one of the big name shops.
    Bob
  7. american opel
    american opel
    from ohio
    i think you should be able to find someone to pull it apart and fix anything that is bad for under $400.unless you want to change the valveboby or go to a trans-brake.the guy that did my ****** only charged me $900 for my turbo-400 and that was with the brake,converter and a whole lot of bigger and stronger parts that would hold up to the 4700 rpm launches.
  8. Pir8Darryl
    Pir8Darryl
    The C-4 is an insanely simple transmission. Buy the book off ebay [or video] and do it yourself.
  9. jughead2
    jughead2
    from tenn.
    C-4 is a simple trans BUT one cant get the valvebody too clean. always replace converter and be very clean with valvebody.
  10. DaveyJonez
    DaveyJonez
    from Houston
    You should be able to get it rebuilt for about $500-$800 on the bench including the parts w/ a warranty and converter. Most good shops will want to use their own parts supplier.
  11. VA HAMB
    VA HAMB
    I had one done about 3 years ago. I cant remember exactly but Im thinking it was between 250-300 bucks.
  12. greaseguns
    greaseguns
    Pir8 is right...if you ever wanted to do your own auto trans rebuild the C4 is the one ....it easy and no special tools needed
