Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. El Hueso
    El Hueso
  2. Cshabang
    Cshabang
    eh...i guess it looks ok Chris...haha
  3. electron
    electron
    Looks awesome, I can't wait to see it out on the salt!
  4. vintagehotrods
    vintagehotrods
    Never sell a '32 unless its your estate sale! :D
    RodNoc likes this.
  5. paco
    paco
    from Atlanta
    Some very nice metal work young man. Looks great.
    PACO
  6. hechtspeed
    hechtspeed
    Wow Chris! So rad! You need to show up at Cars N Coffee in Sandy next to the STi's, EVO's, Corvettes, and what not. haha It will "break necks" as the kids say these days. :)
    I like the stance you've achieved. It's not super dumped low. It's just the right amount of low. It's going to be a shame to cover this metal work in paint, but as long as you/we take lots of pictures of it, we can all be satisfied.
    Keep up the good work. Can't wait to see how it progresses to the Great White Dyno!
  7. Pewsplace
    Pewsplace
    The decision to place the gas tank in the rear p***enger compartment is about the only choice you have when building a sedan such as yours. The battery is another problem to content with. Sometimes safety gets in the way of a good design. I have watched Dennis fill his tank through the window and it doesn't look too hard or unsafe.
    Foley from Reno has a very nice hibboy sedan that has a Halibrand type filler coming out of the drivers side. It may not be your style but it beats having a gas smell in your car all day. I like the tank/bladder idea... even if you have to save a little longer. I wouldn't want anything to happen to you at such a young age as the world needs talent like yours to keep the spirit going strong. Maybe Moal would have some clever ideas how you could build a safe tank. He installs lots of tanks in the trunks of roadsters. My 2 cents.
  8. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    :D Chris You have a great start on your Deuce It won't be long and you
    will be spraying salt........;)
    ...............OL Deuce
  9. HOTRODSWE
    HOTRODSWE
  10. Salt Flats Speed Shop
    from Utah
    I talked to moals, and they get their bladders from fuelsafe. I called them there and they said it would cost me 1,600 to get a bladder. So thats probably not going to happen :)
    Ill just make the tank out of 1/8" aluminum and just work it from there.
  11. Salt Flats Speed Shop
    from Utah
  12. Salt Flats Speed Shop
    from Utah
    I got my front seats today. Ill run the p***enger seat with a cover over it when im driving. Then take it off when its at a show.
  13. Hi!
    Hi!
    from SoCal
    Awsome car. On your gas tank deal, why not put the rear frame horns back on? Tank solved and still look good. I think anyway.:cool:
  14. HOTRODSWE
    HOTRODSWE
    Chris
    Did you try to run stock spindels with bended arms before you decided to go with aftermarket arms? On mine it,s close with the tie rod interfering with the spring mounting hardware. But I would love to be able to run the stock arms for the look. I think the Rolling bones are runing stock arms. What about bended tie rod?
    Any tougths?
  15. pompadour
    pompadour
    Looks killer man your flying!!!
  16. Salt Flats Speed Shop
    from Utah
    The spindles im using were some later ones I had at the shop. I didnt have any 32 spindles. The main thing you want to make sure to have right is the ackerman angle. Basically you want a line from the center of the kingpin through the center of the steering arm, and it should intersect the center of the rear axle. Check this out: http://www.beam-wiki.org/wiki/Steering_Techniques
    I know my car sits a lot lower in the front than the rolling bones do. So I had to use the later drop steering arms to clear everything. On yours you could probably just heat and bend the steering arms down just keep the ackerman angle true and you will be ok. Also look at switching it so your steering rod so it is mounted underneath the steering arm instead of on top. My aftermarket steering arms were tapered on top and bottom so I could choose either way.
  17. Salt Flats Speed Shop
    from Utah
    I got the wheels painted today. Defiantly love the color. My buddy will be striping them this weekend.
  18. bonesy
    bonesy
    Great color on the wheels. Are you ready to leak out the body color yet?
  19. Salt Flats Speed Shop
    from Utah
    two words...washington blue :)
  20. solid
    solid
    F#$king super cool.
  21. HotRodMicky
    HotRodMicky
    Great build!
    So your chop is 5" front and 4" rear ??
    Looks great!
    Michael
  22. Salt Flats Speed Shop
    from Utah
    thats corect. defiantly one of the more dificult chops I've done but my favorite.
  23. boones27t
    boones27t
    from redding ca
    love this car! This will be next build so i can haul the fam around.
  24. HOTRODSWE
    HOTRODSWE
  25. Chris5.7ltr
    Chris5.7ltr
    Very cool mate, love the louvered roof inset!
  26. E.C.
    E.C.
    from Tx
    Awesome!!!!
  27. hechtspeed
    hechtspeed
    Rad! Gonna go google it though, not clear. Darker blue? Love the wheel color.
  28. hechtspeed
    hechtspeed
    I googled it, looks like this right? Washington Blue...
  29. Salt Flats Speed Shop
    from Utah
  30. Patrick46
    Patrick46
