Rattle can, dumbest idea i had...help!
Discussion in 'The Hokey Ass Message Board' started by gunk, May 5, 2010.
  1. gunk
    gunk
    from phoenix
    So i decide to rattle can my 64 C10.....you can see all the streaks. Any idea how to fix. Scotch brite, then respray? Dumb*** plan!
  2. madgrinder
    madgrinder
    The trick is a good fan-tipped spray can.
    Is it satin or gloss?
    Satin... lay a little "dry spray" over the whole thing from about 12-14" away.
    Gloss... scuff each panel and shoot each panel one-at-a-time. Get a coat that is semi-wet enough to flow-out. Use indirect lighting so you can see the wet texture, not just the coverage.
  3. gunk
    gunk
    from phoenix
    Primer. Maybe I should switch to satin. Only have one side done.
    Thanks.
  4. 325w
    325w
    Use one of those handles to make holding the can eaiser. Took 5 1/2 cans to do the 5w.
  5. madgrinder
    madgrinder
    since you are not concerned with texture (primer), just make sure each p*** overlaps the previous p*** by half.
  6. flatheadpete
    flatheadpete
    from Burton, MI
    I washed my shoebox with scotchbrite sponges after it wad dry. Plenty of soap with water, towel dry. It'll even out.
  7. gunk
    gunk
    from phoenix
    Thanks guys. I will try the scotch pad and spray handle.
  8. RG49MERC
    RG49MERC
    When I spray anything with a rattle can I use tips that are use for graffiti.they spray pretty wide and don't really leave streaks..
  9. bikersteve
    bikersteve
    Might be better off buying or borrowing a spray gun, get a can of primer some slow reducer and/or retarder to mix with your primer to increase drying time
  10. smiffy6four
    smiffy6four
    Since I've never done graffiti, not sure which can that might be:p
  11. cheemo
    cheemo
    I would sand it down and try again. Use a Fine paper - like 200 to 320. You might get away with 180 or something but why bother. I am sure you know, but the key to spray paint (and other paint) is thin layers, let it tack up then spray another thin layer. Spray can -> very thin layers = better final result.
  12. cheemo
    cheemo
    I agree with bikersteve. A spray gun would be best.
  13. 59mercsled
    59mercsled
    Go to the hardware store and pick up a pint of rustoleum and then go to harbor freight or steves wholesale tools and buy a $10 spray gun. Mix the rustoleum with thinner 2 to 1 and shoot away. You will have a nice job for under $30 bucks. This is how we did my friends s-10 last year after we had a rattle can disaster like yours.
  14. oh no,...................better call maacco!!!! gotta be cheaper than than many rattle can bombs........just a thought
  15. This is what I do. I painted my 32 frame with Rustoleum Satin and I've had several people tell me it's powder coat. USE THE VALSPAR HARDENER. You can get it from Tractor Supply.
  16. 1962falcon
    1962falcon
    Go to a john deere tractor store you can get a gallon of blitz black paint for 30 bucks, or they offer it in a rattlecan that's made for painting tractors and ****
  17. OldSkoolIronJunkie
    OldSkoolIronJunkie
    Blitz Black is a hot rodders dream, shoots nice in either a spray gun or a bomb can. It also looks very nice when it drys, with a spray gun you change how glossy it is.
  18. Jake H.
    Jake H.
    If you want to get the ****py spray paint off, use a green scotch brite pad and some Comet. Do it soon, though.
  19. AAFD
    AAFD
    from US of A
    Harbor Freight Gravity Feed HVLP Spray Gun = $25
    Parts Store Gallon of Primer & Thinner = $25
    Better finish than spray bombing it anyday.
  20. Death to flat black!
    All part of the played out imperialist sick boy kit! It is because of the abuse of the proletariat m***es by those who insist on making their cars look like barbeque grills that glossy pastel colors and splash graphics will make a comeback!
    If we communists believed in hell we would say, "To hell with the flat black barbeque driving capitalist bandits!"
    Phuck Mi? No, Phuck Yuuuuuuuuuuuuuuuu!
  21. THE_DUDE
    THE_DUDE
    Fan tips and one panne lat a time, hood fender door bedside
  22. Cadillac Jason
    Cadillac Jason
    Def. get a gun and gallon. it will look really smooth if you just overlap your lines as you go and make sure you practice on some cardboard panels to get it down and build confidence.
    Good Luck
  23. Muttley
    Muttley
    You know you've arrived when Ngo Long Dong makes an appearance on your thread. How are things at the spark plug factory?
  24. UnsettledParadox
    UnsettledParadox
    i just rattle canned the bottom half of my car. forgive the glare in the picture off the chrome, its the only one i took today and its dark out now!!
    anyways, a lot of guys wanna get "the good stuff" when they rattle can so they go rustoleum. ive found that stuff covers great but is more likely to cause "tiger stripes" as we call em. we use the krylon stuff. it doesnt cover as well and takes more p***es and a couple cans more but the cans come with a nice fan tip and spray really well. just take your time and layer it on. your not gonna get it to cover your first p*** so just get an even coat on a panel, let it dry for a min and start again. repeat until you feel its thick enough and you are sure you dont have "holidays" aka light spots.
    also, flat is the easiest to lay down, satin coming in close second. its the gloss you really have to work at to avoid tiger stripes
    the rustoleum is $5.00+ a can and the krylon is $2.87? a can. i just did mine yesterday! ive got some sanding to do on the roof before i rattle can it
    also forgive the stupid fender spears...they are coming off soon!!!
  25. flyingbohemian
    flyingbohemian
    google montana ******** spray paint
    They make spray paint specifically for graffiti, and sell caps that will fit most paint cans. They should help with what size you'll need.
  26. koolkat
    koolkat
    from Merced CA
    Spray each panel side to side, then vertically, then diagonally each way. Then a final wet coat.
  27. modelacitizen
    modelacitizen
    The trick to rattle canning stuff is layer on layer spread evenly with lots of sanding between each coat. It just takes forever.
  28. Goozgaz
    Goozgaz
    A cheap spray gun and a gallon of primer or even rustoleum.It will cost you half as much as all those rattle cans.
    Just be careful. Once you shoot your own primer, you'll see how easy it is and you'll want to start shooting real paint over it.
    Don't be afraid to spray your own car.. it's easy.
  29. how many cans do you guys usually use? I've never sprayed canned a car but always wondered that
  30. cleatus
    cleatus
    from Sacramento
    It's always good to see Long Dong.
    No wait, that didn't come out right
