jreeder's model T
Discussion in 'The Hokey Ass Message Board' started by jreeder41, Apr 6, 2010.
  1. jreeder41
    jreeder41
    He is my build thread for my 1926 Model T touring. I have a two kids so the touring body will work out great. I have a model A frame, model T rear spring, 8AB flathead, 3spd with overdrive merc ******, and 39 rear. The body is being delivered in two weeks. I have the frame gutted and boxed and currently I'm working on mounting the rear and engine/trans. I plan on painting the car a medium green with a cream wires and suspension. This is my first personnal hot rod so I'm pretty stoked!
  2. 117harv
    117harv
    Going to be a very cool ride, i like the color combo. Will you be running it with or without the top?
  3. Cool! My next project is a '26 roadster on an A ch***is. I'll be watching this one closely.
    -mikethegreek-
  4. HomemadeHardtop57
    HomemadeHardtop57
  5. butch27
    butch27
    That frame looks STRONG- good work.
  6. thunderbirdesq
    thunderbirdesq
    That body looks GREAT! Go Jon Go!:D
  7. Stick Shift
    Stick Shift
    from LENA IL
    Kool. I got a 26 touring. I was planning on doing the Model A ch***is too, but I am thinking about going the 32 route somedays. LOL
    I like your choice of colors too. Good Luck on your build.
  8. kwmpa
    kwmpa
    from Pa
    Whats that it looks like a buggy...haha:D
    Shamless plug for the shop:D
  9. bct
    bct
  10. I am looking forward to following this one, as I would like to do a touring when I clear some space in the garage. Good luck and keep us posted.
  11. jreeder41
    jreeder41
    Probably no top. Kevin is going to make me a tonnue cover for it.
  12. jreeder41
    jreeder41
    "Whats that it looks like a buggy...haha:D" Kwmpa
    Yep that's what my daughter thought. "Dad are you building an amish buggy?":eek:
  13. jreeder41
    jreeder41
  14. jreeder41
    jreeder41
    Got the body on Sat. So Sun my wife and I mounted the engine/trans and sat the body on. My daughter loves it!
  15. jreeder41
    jreeder41
    Messed around a little last night and got all 4 latches working. I need to find strikers for the front two doors. Luckily all the hinges are in good shape. A little PB blaster and everything is working good.:cool:
  16. jreeder41
    jreeder41
    Starting fitting up steering column. It is a ross box from a 34 IHC. Also worked on a template for the dash.
  17. thunderbirdesq
    thunderbirdesq
    Damn, you don't mess around, Jon! This thing is gonna kick ***!!!
  18. jreeder41
    jreeder41
  19. jreeder41
    jreeder41
    Worked on the T a little yesterday. I sectioned 2" out of the rad shell and installed the rear under the car.
  20. flatheadpete
    flatheadpete
    from Burton, MI
    I'm watchin' this one.
  21. jreeder41
    jreeder41
    Some pics from last night. I fabbed up a new dash and fitted to the car. I'm going to use rivet head screws to hold it in the car, right now I just used some 1/4" bolts. I'm trying to decide which gauges to use. I have a complete 55 packard dash and a unknown speedo I picked up at Hershey.
    I was thinking about using the turn signal arrows and mesh background from the packard. I would cut it between the outer gauges and the switches. Not 100% on which way to go so opinions are welcome!
  22. jreeder41
    jreeder41
    bump for opinions
  23. sawzall
    sawzall
    speedo is 46 47 or 48 ford.. i like it mounted in the center..
  24. Jerry27Tub
    Jerry27Tub
    Dude, that's looking sweet! Good work -keep it up.
  25. captainjunk#2
    captainjunk#2
    very cool dash making progress good luck on your build
  26. jreeder41
    jreeder41
    Here are some pics from the past the weekend. Put in the rear wishbones and made a trans mount.
  27. jreeder41
    jreeder41
    What do people use for the pivot bolt on the trans end of the bones? Also what else do you but in to replace the strength of the torque tube?
  28. A heim for the bones and a torque arm to replace the torque tube. Look at Hot Rod Works site for ideas. There are also DOZENS of threads along these lines, Nealinca did one of the nicest torque arms
