10 Bolt Third Member, 2.23 Gear Ratio
Discussion in 'The Hokey Ass Message Board' started by Candy-Man, May 9, 2010.
  1. Candy-Man
    Candy-Man
    Looking for the Chev car which had a 10 bolt, 2.23 ratio third member ? Anyone have any idea's.... Diesel powered possibly....
    No it is not for the street, it is for a Bonneville car...
  2. Hubbcat
    Hubbcat
    from Sweden
    bought a chevy malibu 78-80 axle that had some thing like that but it was the 7,5 type.
  3. Candy-Man
    Candy-Man
    Thanks for your reply.... My buddy is running a 10 bolt in his Bonneville car with hydraluic tubing used for axle tubes adapted to Ford 9" axles..... However; he purchased the gears off of ebay and the seller was not aware of what the donor car was...
  4. frank dog
    frank dog
  5. F&J
    F&J
    Any chance there is the GM part number stamped into either gear? I thought some were marked?
    If so, do a google like " GM 3****** " sometimes you will get a match. If no match, bring the number to a friendly GM parts counter guy.
    best I can do.
  6. weim55
    weim55
    The only one I know of that's close is the 12 bolt car '65 to '70 could be special ordered with a 2.29. Very rare.
    Never heard of a 2.23 in an 8.5 10 bolt. Seems pretty likely though. I've seen 2.41s. Maybe try to see what GM full size diesel cars had for a ratio in the '78 to '84 era .
    Steve weim55 Colorado
  7. Larry T
    Larry T
    A lot of the Firebirds with 8.5" 10 bolts had REAL tall gears. Does 2.29 sound right?
    Larry T
  8. Rudebaker
    Rudebaker
    from Illinois
    You looking for a carrier or gears? I've never heard of 2.23 gears for a 10-bolt but I wouldn't be surprised. If you already have the gears a 2 series carrier from a 2.41 or 2.56 should work and I believe Larry T is correct on the 2.29 geared 'Birds. I think a lot of the late 70's early 80's full size GM's had 2.29's too.
  9. Candy-Man
    Candy-Man
    Larry: You are probably correct on the gear ratio, as I was not sure on the ratio, just going from memory.......
    Thanks.....
  10. B Lawrence
    B Lawrence
    from Ham.
    Neil......Garys 2.29 set is out of 78 malibu and his 2.41 set came out of a Irac eee taxi. Still running the 2.29"s no probs......see ya.
  11. Pete
    Pete
    Candyman,
    I have one of those rear ends in my shop. It's a 10 bolt Posi.
    Pete-
  12. SafariTow
    SafariTow
    GM made a 2:14 in a 10 bolt metric 7.5 around late 70's through 84 i think, hard to find. monte carlo, regal, ect. I had to go with a 2:41 for my Diesel Hot Rod.
  13. lincolnolli
    lincolnolli
    from Germany
    My 78 Chevy Monza came with 2.29 from the factory.
    10 bolt axle but 7.5"
    Ollie
  14. Hnstray
    Hnstray
    from Quincy, IL
    The '79 (only) Cadillac Seville has a 2.28 10 bolt ........either an 8.2 or 8.5......I have one I was planning to use on a pickup project...........The '79 also has 5 x 5" wheel bolt pattern........earlier versions ('76 & 77.....not sure about '78) have 5 x 4 3/4" wbp.............The width hub face to hub face is 59" (maybe 59 1/2) they are disc brake equipped but will take normal 10 bolt drum backing plates.
    Ray
  15. Candy-Man
    Candy-Man
    Excellent thanks guys....
