chop to a 48 Ford p.u.
Discussion in 'The Hokey Ass Message Board' started by b-bob, Apr 17, 2010.
  1. b-bob
    b-bob
    Pushed the truck outside to clean up the shop today. Stood back and took a couple of pics for you.
  2. LabRat
    LabRat
    Nice Chop , compliments the flow perfectly .....
  3. billys54
    billys54
    impressive!!!!
  4. b-bob
    b-bob
    Talked to him today and got some more information. As said before the truck is chopped 3inches, stretched 5 and is also channeled 3 inches and all four fenders are sectioned 3 inches. One bar has been eliminated from the grill due to the sectioning of the front end. The doors have also been suicided.
    Maybe o/t, but here is a picture of his current driver and below that one of his current project.
  5. b-bob
    b-bob
    Now that all the cutting and welding and grinding is done, i am so glad i listened to you guys and stretched the roof. I had originaly planned to lean the posts, and that would have been a lot easier. But the stock shape of the posts is much better, well worth the extra work.
    I have done a bunch of cars and this was my first attempt on a F-1 pick up. Or in this case a M-47, being a Mercury.
  6. P-townkustoms
    P-townkustoms
    from P-Town CA
    Awesome job, looks fantastic. Do you happen to have an extra Merc tailgate????
  7. b-bob
    b-bob
    No, i don't have an extra tailgate. The one i have is going to need some attention too. Did you know that the Merc tailgates are actually Fords with the FORD cut out and a little plate that says Mercury is spot welded in.
  8. HOT40ROD
    HOT40ROD
    from Easton, Pa
    I guess I went through a lot of extra work quartering the roof. I had two roof and cut each quarter long and trim it to fit. That way there was no 1 -2 seem to weld in.
    My self I like the mail slot rear window.
  9. rustyhood
    rustyhood
    b-bob she is lookin great! Nice job!
  10. b-bob
    b-bob
    Finally got a coat of primer on it. Now on to the vent windows.
  11. Antny
    Antny
    from Noo Yawk
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    That looks GREAT. So nice to see restraint. I'm taking notes.
  13. pinstripebob
    pinstripebob
    from Carmel, IN
    Wow dude, that looks awesome! Keep it up!
  14. b-bob
    b-bob
    An update on the truck. I have filled the cowl vent and the gas filler and misc. mirror holes and finished stripping the hood and two doors to bare metal and fixing a small rust hole in a corner of a door. I have also used a modern Ford p.u. box floor to replace the wood one. Far less expensive than buying wood and runners and hardware. The truck will now go back in the corner, while i work on a new project for a friend. Hope to get back on it in the fall, i would like to drive it next summer in some shade of tinted primer of course.
    A great summer to all you HAMB guys and gals!
  15. mikemf100
    mikemf100
    from ILL
    looks great thanks for the info
