chevy -stock 6 lug..long enough for bolt on wheel spacers?
Discussion in 'The Hokey Ass Message Board' started by MarkKoch, May 10, 2010.
  1. MarkKoch
    MarkKoch
    from Maryland
    I picked up some late model steel wheels,there 15`s and well I got the rear on and ***umed that if they worked/fitted well that the front would be the same-...wrong..there about 1/4 to much on the backspacing..only have problems in turns.Didnt even put a mile on them and took the car rite back home.I was wondering if the length of the stock wheel studs are long enough for the bolt on wheel spacers w/studs attached.W/ the stock wheels on there are only about a thread or two show through the lug nut(eggcorn style).Thanx
  2. MarkKoch
    MarkKoch
    from Maryland
    Any body have any info on this?
  3. Bad Bob
    Bad Bob
    from O.C. Baby
    When I read "Late model"......i'm out!!!!
  4. Ice man
    Ice man
    Check out Gary at Rally America. com. They helped me put my 35 Ford wires on Chevy drums. Good Service. Iceman
  5. Well are they plain nuts or the type that unilug mag wheels use?
  6. MarkKoch
    MarkKoch
    from Maryland
    There the plain ones
  7. OldSub
    OldSub
    If only a thread or so show the studs are too short to use a spacer. You need a minimum of a couple threads showing to be safe.
