Hot Rods 29 Ford X-tra Cab Truck
Discussion in 'The Hokey Ass Message Board' started by DirtySanchez, May 12, 2010.
  1. DirtySanchez
    DirtySanchez
    from So Cal
    I finally rolled it out into the sunlight for it's first actual viewing. It originally started as a Murray bodied touring sedan. I cut the rear doors out, and filled the rear wheel wells. It's chopped 6", channeled 4.5", and rolling on a 104" wheelbase. I still have to finish shortening the roof section above the doors. Flathead 8BA backed by a T5, followed by a Ford 9". 1940 backing plates with Buick drums for the front brakes. I'm running the 40 front spring on the rear, with a few leaves removed. I've gotten a set of Edmunds heads and two pot intake to be added when the paint and detailing comes into play. I still have to mount the Schreoder box and Ansen pedals, and figure the exact spots for the wishbone/trailing arm mounting points, then begin the interior.
    This is my first Hot Rod build and appreciate any input of things to consider regarding the things left to do.
  2. Mat Thrasher
    Mat Thrasher
    I like it, nice job on the proportions. I think its easy to screw up the extended cab truck. Also I think the full hood really ties everything together. Keep up the good work.
  3. Dean Lowe
    Dean Lowe
    X 2 on the proportions and the hood. This build shows a lot of thought and planing. I like it. I would never guess it is your first build. My only suggestion is give it shiney paint! This car deserves to be finished right.
  4. Imwalkin
    Imwalkin
    from Tucson, Az
  5. Big Khaunaa
    Big Khaunaa
    looks like a baboons ***
  6. DirtySanchez
    DirtySanchez
    from So Cal
    Thanks guys (Except that "Khaunaa" rahtard. Maybe learn how to spell Kahuna before you chose to use it in a public domain) . I appreciate it. I'd forgotten the paint details. I do plan on painting it. My plan is gloss black with the thin body line being silver leafed. Not decided whether verigated or burnished yet though. I thought it would give it a trim piece look that I don't think has been seen too many times.
  7. Roupe
    Roupe
    Is that good or bad?:rolleyes:
  8. Big Khaunaa
    Big Khaunaa
    love you buddy truck looks bad ***
  9. DirtySanchez
    DirtySanchez
    from So Cal
    Thanks mang. (man hug) Dude, did you just cup my ****?
  10. I started to say that those are usually called street rods but yours is definately not a street rod.
    Looks good from where I sit friend.
    Edit Damnit
    Good short wheelbase, ought drive like a go cart. Thats not a bad thing.
    I'll tell you something that I would do before I did final detailing and paint, especially since it is your first rod. Get it road worthy and drive it around for awhile. Get the bugs worked out of it, make any changes that you have discovered would make it better or more correct then blow it apart for detail and paint.
  11. scootermcrad
    scootermcrad
    I dig it!! Great proportions for sure! The hood looks awesome on there!
    What did you use to fill the wheel wells?
  12. Looks wierd inthe little thumbnails but spot on when you blow up the pictures. I dig it.
  13. kookee
    kookee
    Looks good! Like some have said, many miss the mark on proportions.
  14. DirtySanchez
    DirtySanchez
    from So Cal
    Scooter- I used 18 ga sheetmetal. Rolled and hammered to fit the vaious contours. I even managed to make each filler out of a single piece too. It was the rear portion, at the bottom, that gave me the biggest fit.
    Thanks again guys.
  15. 49ratfink
    49ratfink
    nice proportions. I like the hood.. don't see too many hoods on this style of car.
  16. scootermcrad
    scootermcrad
    Yep! Had the same issue with mine. I ended up using a '52-ish chevy hood to get the conpound curves.
    Do you have more build pictures somewhere??
  17. DirtySanchez
    DirtySanchez
    from So Cal
  18. scootermcrad
    scootermcrad
    Oh yeah! I've seen that thread. Okay. I thought it looked familiar, but hadn't looked at it for awhile. Great progress for sure!
  19. GEBHARD
    GEBHARD
    from TX...
    looks tuff... perfect height and stance, good job!
  20. Kinky6
    Kinky6
    Hey, Sanchez, I like what you have started here. The one thing that I would suggest is to check on the roofline profile as you are completing the body.
    There was someone else who was doing something like this w/ a 30-31 IIRC, and the sweep of the rooflike left an odd hump from having removed the rear door. You may have to cut a long, thin wedge section (wide at the front ) out of both sides above the quarter windows to match the roof sections above the front doors; just enough to get a nice flow from the front edge of the roof back to where it rounds off at the rear.
    I'm diggin' your big back window Chevy, too. What year is that?
    Later, *****6 :cool:
  21. DirtySanchez
    DirtySanchez
    from So Cal
    Thanks for the heads up on the roof. I'm thinking I will be doing the roof filler out in the driveway, so I can stand further back and address what your talking about. I hadn't tought of it until you'd mentioned it. BTW-It's a 55 Cameo.
  22. scrap metal 48
    scrap metal 48
    Most everything's been said so I'll just say it's really cool........
  23. scootermcrad
    scootermcrad
    Yep! That was me... What a PAIN IN THE ***!!! I used a slant window body though. They're just a little different than his. My quarter windows had a much more obvious discontinuity than his and they were longer, making it worse. I also had this issue with the roof line and had to do a ton of work to get it to line up right...
  24. So-cal Tex
    So-cal Tex
    Stan,
    You gona have it at the Club show in July?
    It looks good and I can't wait to see it person. You build a pretty good hot rod for biker trash.
  25. DirtySanchez
    DirtySanchez
    from So Cal
    Im shooting for our July show. No paint obviously. But besides the financial portion, I think it's doable.
  26. DirtySanchez
    DirtySanchez
    from So Cal
    Anyone recommend a radiator shop in the Southern California area to build a custom radiator or a type radiator that would fit a model A shell width and modified from there?
  27. resqd37Zep
    resqd37Zep
    from Nor Cal
    Truck looks great! Keep doing what you're doing.
  28. fiftyv8
    fiftyv8
    from CO & WA
    Great job, no dirty work there!!!
  29. rustyhood
    rustyhood
    X2 I like it and will be checking on your progress. Good luck.:rolleyes:
