'31 model a cowl
Discussion in 'The Hokey Ass Message Board' started by barnbikes, May 13, 2010.
  1. barnbikes
    barnbikes
    from MN
    Picked up a 32 cowl about month back. Was looking at it last night and noticed a tube running from top of the p***enger side windshield down to the fire wall.
    Did they have vacuum wipers on Model a's?
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    31 or 32?
    got me confused..
    than you say Model A.(we all know the 32's were not called A's).now im really not sure where your at
    but its possible they could have had a vac. wiper
  3. rustrodder
    rustrodder
    Pretty sure thats the vent for the gas tank on a Model A
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    not to say no..on this, because i have learned alot i didnt know on here..but my 28 A has a vented fuel cap..so no need for a tank vent tube ..especially one that comes into the car and above the windshield?:eek:
  5. el Scotto
    el Scotto
    from Tracy, CA
    Picture? Bueno?
    Does it have a cowl vent or a gas tank?
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    The vent on a Model A gas tank is called "the gas cap".
    That tube is the vacuum line from the windshield wiper motor to the firewall.
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    guess that would have solved and answered all my questions:eek:
    yeah break wide with the pictures man:D
  8. millersgarage
    millersgarage
    it's for the wipers
  9. Ravenwood
    Ravenwood
    from Texas
    You've found Granddad's old cowl! The tube did come from the gas tank. It was the earliest attempt at a gasoline heater. Granddad dreamed it up. He installed it. He lit it. Then he went to heaven. :D
  10. Model A Speedster
    Model A Speedster
    Early Model A's were equipped with electric wipers (on the driver's side only). Later ones - perhaps mid-1930 on ran vacuum wipers. The vacuum tube ran off the intake manifold at the split for cylinders 1-2 and 3-4. The line for closed cars ran through the cowl on the p***enger side and up the pillar where it connected with a rubber hose that ran along the windshield hinge to the wiper. Some body styles had the wiper motor mounted inside the car while others put it outside. Early early models and commercial units were furnished with a hand wiper. I had one of those; it was a joy to drive in the rain! Kept you busy... To my knowledge, the only vent for the gas tank was built into the gas cap. On the screw-on type caps (28-29) it is easy to get the radiator and gas caps mixed up. The radiator will continue to radiate, but the gas tank will not vent and the car will starve for gas until you correct the mistake.
  11. 29nash
    29nash
    from colorado
    Model A Speedster; That's the truth.
  12. barnbikes
    barnbikes
    from MN
    Here is a picture of the cowl.
  13. Da Tinman
    Da Tinman
    did you pay 32 price for it?
  14. Rehpotsirhcj
    Rehpotsirhcj
    looks to be a 30
  15. seventhirteen
    seventhirteen
    from dago, ca
    windsheild wiper vac line
  16. doctorZ
    doctorZ
    yes, it's a vacuum tube for the wipers.
  17. barnbikes
    barnbikes
    from MN
    I gave the guy a $100 for it. figure I could put the tank and sell the tank for more if I wanted too.
  18. johnny bondo
    johnny bondo
    from illinois
    id be interested in it.... its a 30 btw.
  19. AV8Paul
    AV8Paul
    why could it not be a '31 too?
  20. jkherd
    jkherd
    vacuum wiper line
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    30-31..
    nice score for the $
    there might be a date stamped in the firewall..near the top ..that might tell you year exactly
  22. Model A Vette
    Model A Vette
    It could be 30 or early 31. Late 31 had a big indent in the firewall for the engine compartment mounted gas shutoff.
  23. johnny bondo
    johnny bondo
    from illinois
    i could but they had more 31s with the indented firewall.
