Need to raise the rear of the 56 ideas?
Discussion in 'The Hokey Ass Message Board' started by meatball, May 10, 2010.
  1. OK my 56 has been held up off the tires by air shocks for ever however I tried to use a new set of airshocks (monroe not Hijackers) I needed to use extenstions on them howeveer it snaped the damn shock at the top.Maybe it has something to do with the angle however its got shackles but I still need to raise the damn car about 6 inches or more,without breaking the bank,IDEAS???
  2. THE_DUDE
    THE_DUDE
    Well. plenty of ideas. But about how to lower it
  3. tony31a
    tony31a
    Flip the axle on the other side of the spring (the opposite of how everyone lowers their trucks) $12 for new spring pads and an afternoon of work.
  4. I dont think so tim..........errrrr Dude this cars been like this since the 70s
  5. THE_DUDE
    THE_DUDE
    X2 on that one I am sorry about my prior comment I didn't know it was a straight axle car. Mr gasket sells new perches
  6. thought about that ,however then the ladder bars wont work and the spring wrapup would be serious when I get on it............I think
  7. THE_DUDE
    THE_DUDE
    Could add more leaves to the Rear.
  8. thats cool......I thought I had posted a complete pic....
  9. metalshapes
    metalshapes
    There is a Spring Place on Grant ( across the street from where the Harley Place used to be ), I'd ask them if they could put a little more arc in your springs.
    Adding leafs or using Wagon springs could work too, but that would raise the springrate a lot and that could mess up your ride and handling.
  10. Ride? its really stiff now but I need to check on the re-ach,just thinkin its to much cash right now..........
  11. lorodz
    lorodz
    what about lift shackles ..have you thought of them ..so you can add a couple inches in the rear ..
  12. i run lift shackles on the ranchero, it changes your pinion angle drastically though so you have to put new perches on the rear end.
  13. beernut
    beernut
    from solvang
    my son was telling me about this the other day,remove springs,pull apart leaf pac,put main leaf in press use angle iron to bend the spring every 2"
    do the whole spring that way and you will be surprised how easy it will bend and re-arch,lay it on its side on the floor and draw the arch so you can make them both the same
    you dont need a super big press to do this ether
  14. this is kinda where Im leaning now,maybe a combo of a couple of ideas.and yeah I gotta confirm the correct pinnion angle also..........
  15. brad chevy
    brad chevy
    Just a idea,why not check with some of the 4-wheel drive shops,alot of the off-road companies make alot of different length shock applications,but it looks like adding leafs to the spring is the cheapest way to go.
  16. carlos
    carlos
    from ohio
    change the shock location and use the air shocks without extenisons,but the best is a new set of springs with bigger arch a good spring shop can make you want you want
  17. yeah springs are the best but $$ I dont have right now,the extenstions was really a bad idea cause of the angle.I am making them more straight up and down as there is a beam welded into the frame there.so something has to happen............the top pics are the height I need to be at and that was woth the old airshocks (hi jackers)
  18. Why won't the ladder bars work? You'll maybe need to drop the front mount a bit.
    Coil springs on top of the axle works or get the leaf srpings arched. Firestone makes an air bag setup that's pretty cheap for leaf spring pickups that should also do the trick for you.
    Flipping the axle will get you about 3 inches BTW or the basic thickness of the axle tube +/-.
  19. StanDaManTX
    StanDaManTX
    from The South
    Contact St.Louis spring. They are super affordable and really fast. Ask them about adding leaves. Have you flipped the shackles yet? On my 59 Ford, I put a cheap floor jack on the spring(wheels strattling the leaves) then cranked on the jack so that it lifted on the frame. POP! The shackle pops down and I had at least 2 inches more height in the rear.
  20. ENFO
    ENFO
    from Tucson AZ
    I think you should check on the price of getting the spring re-arched before you say its to exspensive.... a friend it done a while ago... and it was under $100 And it wont be a band aid, it will be an actual fix.
  21. Shawn give me a call..........I was at AZ Spring yesterday.........
  22. Mr48chev
    No, they will screw up what springs he has in a few miles and that may be the cause (or a big part) of the problem he is having now. Any of us where around in the 70's remember all of those jacked up cars with extended shackles and the springs ending up loosing all of their arch. Some scary sights when they go around corners too.
    The correct way to do it is to have a spring shop re-arch or rebuild the springs so they raise the car up where he wants it. To keep the look he has that is.
    Probably the truly correct thing is to narrow the axle and tub the thing. But it wouldn't have that stupid 70's look with the rear tires sticking out of the wheel wells like a 4x4 then and loose all of it's 70's flavor.
  23. jcmarz
    jcmarz
    from Chino, Ca
    I had a 57 Chevy back in the late 70s that was lifted pretty radical with longer shackles out back. A lot of jacked up street machines had longer shackles to raise the rear. They (longer shackles) used to be sold by JC Whitney or your local auto parts store. I had heavy duty wagon coil springs up front.
  24. COrrect to tub,yeah and look like POS 80s pro-street car that wouldnt track if it had to (had one!).as far as handle it is/was so stuff I had zero body roll in corners.So I guess I will keep that 70s "stupid" look on my car that was built in the 70s........thanks everybody for the input.and yes Im redoing it right and not just woth airshocks this time
  25. B.A.KING
    B.A.KING
    shackles,new station wagon springs.7 leafs.i think? do you have the shock mount on the top that goes from frame rail to frame rail? or still bolt thru the trunk floor?
  26. metalshapes
    metalshapes
    Hey, I've got a Sawzall...
    Want me to get those fenders out of the way for you?:D
  27. WHAT?!?!?!?!?? does this look like a damn Capri??:D
  28. OK its got shackles (they might stay) and the shock mounts on the top are a cross member welded into the frame aligning with the bottom of the frame rails,and I gotta flip the bottom mounts Im sure to gain about three inches there,only thing in the floor is two access doors to reach the to of the shock
  29. GaryB
    GaryB
    from Reno,nv
    I belive i used 57 station wagon and got about 2in .back in late 60's early70's .wish i had that car back....damn
  30. mrgasser396
    mrgasser396
    from NEW YORK
    JC WHITNEY sells extra high lift front coils and rear leaf springs for 55 -57 chevys
