Customs 1949 Thunderturd.
Discussion in 'The Hokey Ass Message Board' started by VOODOO ROD & CUSTOM, Jan 31, 2010.
  1. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
  2. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Just playin' with the larger images thing ! ! !
  3. torchmann
    torchmann
    from Omaha, Ne
    You nailed the proportions man!
    It has the shape of the 2 door 4 p***enger sport coup.
    Just about the same placement on the body of everything in a t bird
    That long hooded thing on the trailer was uuuugleeeee and looked more like they tried to make an Opel gt out of a 49 ford
    Yours looks like it was made that way by someone who could have made money with it as a genuine model
  4. koolkemp
    koolkemp
    Time to upgrade the Photobucket !!
  5. brad chevy
    brad chevy
    There wasn"t but 3 years of the Thunderbirds that made an impact anyway 55-56-57- just like Chevy in 58 all the car designers went to hell on design.,line up all the 58 and 59 cars and it was hard to give the award for the ****piest look.The designers for the new kits that are being put on the fords and now a damn camaro with a fibergl*** 57 front and rear must have been kin to them cause they missed it completely.and Iain"t downing 58 Chevies ,the 2-door can be made to look descent,but the 58-59 bird no hope.
  6. 62rebel
    62rebel
    where's the project stand right now? need more PICS! i've always looked at moredoor cars as the starting point for custom coupe designs. it was a long time before i got into the concept of sectioning as well as shortening, to get the proportions right (seeing as how all i had to work with was pen and paper at the time!)
    you definitely have motivated me to search out a likely shoebox moredoor to try this on.
    too bad this concept won't fly on my '59 Galaxie...
  7. Gotgas
    Gotgas
    from DFW USA
    What??
  8. ...what he said...
  9. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Does anyone know WTF is going on with the photobucket deal ? ? ?
  10. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I'll try this again ! ! ! I'm a newbie to this Photobucket stuff ! ! !
    BigRRR and chryslerfan55 like this.
  11. cheveey57
    cheveey57
    Looks great so far & although the idea of skirts might be cool, the skirts posted are waaaay off.
  12. JamesMcD
    JamesMcD
    Skirts don't fit the European character of the car. And please don't move the rear wheels. I think the proportions are just how they should be.
  13. 64 Wildcat
    64 Wildcat
    I'd agree. Looking at the original sketches, the car's lines are very reminiscent of the Chrysler Ghia specials of the 1950s. Look forward to seeing progress on your project.
  14. I wonder if that's the same shoebox someone was selling off Amber Road like 15 years.. maybe 20 years ago. It was parked on the end of some side road where the main road makes about a 90' left turn as you go away from the lake. I remember it wasn't in bad shape, but the interior was rough, it was black, but I forget if it was a 2dr or a 4dr.
  15. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I finally remembered the Camera. Just closed up the shop. Got the Flatty running this evening. Seems to run sweet. Was just running it on the ol' pour some gas
    down 'er throat...... I am attaching images taken this evening. The current work is extending the pedals, positioning the steering column and wheel. The dash has
    been moved back 12". The gas pedal rod has been lengthened 12", the Clutch pedal rod has been lengthened 9 1/2" and the Brake pedal rod has been lengthened 4 1/2". The steering column will be positioned as seen. The section is 4". The "repositioning" of the column will be approx. 3". I'm still "engineering"
    the steering column mounting and transition to the steering box. I've located the battery into the Trunk and
    run all new 2 guage wire to the Solenoid and Starter.
    I have wired one of the Speedway (pull type) ignition switches. The gas tank is out and in the process of being cleaned. There was approx. 12 gallons of 30 year
    old gas in the tank. Varnish city. I'll be running the engine on a one gallon gas can for now. I just scored a
    Hurst Master Shifter 3 speed shifter on E-Bay. My next step is going to be fabricating the mount bracket and shift arms and getting the whole floor shifter installed.
    I need to cut and reweld the Drive Shaft. At that point,
    it'll be running and driving. After that, Weld like Hell ! !
    Stay tuned .
    I guess that I'll have to restore the ol' Gas Pump also.
    Oh ya, I also chopped the Factory Front Bench Seat 8".
    (4" section and 4" chop).
    Trunk Mounted Battery .
    chryslerfan55 and kidcampbell71 like this.
  16. Buick59
    Buick59
    from in a house
    Im looking forward to seeing this progress, what a cool concept.
  17. marshallal
    marshallal
    from amherst ny
    Now i see the photos...........mlmlml
  18. 62rebel
    62rebel
    i continue to be impressed but the pedals are "kinda" scaring me.. have you considered fabricating new arms in one-piece that won't depend on a bolt/nut for attachment? just saying, that bolts and nuts work loose, and risking yourself and a rider.... oh, AND the car... worries me.
    that said... i gotta find me a suitable moredoor now.
  19. roddinron
    roddinron
    Please don't leave those pedals like that!:eek:
  20. 62rebel
    62rebel
    the more i look, the more i see.... i like your vision but i really want to find my own moredoor now. i had a hard time understanding the setback of the cowl until i realized the wheelbase hadn't been altered... definitely going to steal your ideas and work off them. now... please... FINISH IT!
  21. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Believe it or not, the Clutch and Brake Pedals are really solid !! ??
    The Gas pedal is shakey due to it being Rubber. Since I'm just in
    the mockup stage, I will most likely go with a underfloor Brake and Clutch ***y (ECI brakes) and do something different with the Gas pedal. Right now, I'm shooting to get the car running and driving (for mobility's sake) and then I've got to get welding. Gene Winfield is doing his metal Seminar at the shop next month, I'm going to let Gene take a look and give me some
    real "old school" input. Thanks for the comments, I appreciate
    feedback. Feedback is what makes a project "come together"
    with a constant stream of fresh ideas. Search "Gene Winfield"
    if you're interested in attending the seminar in July.
  22. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Just found the Jim Weimer Rod Garage Mustang II set up specifically for the Shoebox. It is a complete kit with Brakes
    and all for $ 1,795.00. I have been battling with the brakes,
    steering, clutch, etc...... Now that I've looked over this kit, I'm
    sold. Jim Weimer Rod Garage will be in Syracuse for the Syracuse Nationals July 16 - 18, 2010. I'm going to hook up with them at the show and do the deal. I'm pretty sure that I'm
    also going to use the ECI Brakes Inline Brake and Clutch set up .
    This will tackle all of my Front Suspension, Steering, Braking and
    Clutch set ups all at once. Just dropped off the Drive shaft Friday to have 14" taken off. For all those that didn't like my
    pedals, they will be utilized for temporary moving around of the
    car while the Bodywork is being done. I feel that this set up will
    be down in the dirt and handle well and Brake well. I'm going to
    keep the Flatty and 3 Speed. I'm in the mock up stage of installing the Hurst Mastershift 3 Speed Shifter. I'm fabbing up
    a bracket to mount the shifter to the stock 3 Speed. Just figured that I'd give an update since I've been working slowly but surely
    on the TURD >>>
  23. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Just mocked up the 3 Speed shifter plate. I'm using a Hurst Mastershift 3 Speed Shifter. I am using the original 3 Speed Transmission behind the original Flatty.
    Here are some images of the Transmission Shifter Adapter plate I made last night. I'll give 'er a try today.
    I made a pattern, so all should be good.
  24. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Wow , I can't believe that I haven't posted an update in almost
    3 months ! ! Just trying to catch up with the back of the Bus !!!
    I figured I'd put some images of the 3 speed shifter bracket
    now that it is installed in the car. The car in 100% running and
    driving at this point. Now that the Gene Winfield seminar,
    Syracuse Nationals and Summer are gone for that matter, it's
    time to dig in to the bodywork. Here are some fair images of
    the shifter mounting bracket......
    I know, I know, the pedals are scary. Just temporary to move the car around while the bodywork is being done.
    VR&C.
  25. Pete Fox
    Pete Fox
    from Belgium
    Hi,
    Did you make any progress in this last month? I can t wait to see this car finished!
    I had the same idea a few years ago when I could buy a 1953 Ford Mainline four door over here in Belgium and after reading the march 1953 Hop Up magazine where there is an article called Practical Restyling where they describe doing the same on a 1952-1954 Ford. Did you read this article allready?
  26. big bad john
    big bad john
    ..........I like the look......keep us posted....
  27. Crease
    Crease
    Im as impressed with the vision as I am the skill, very nice!
  28. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    It's been a slow go recently. I am going to be digging into this build once Winter sets in. I am basically at the point where I need to weld the whole body together and finish up on all of the bodywork. I've been out of town a lot lately and time is minimal.
    I do take the car out in the fields and do donuts on weekends just to blow off some steam ! ! ! You should see the look on peoples faces when they see the Thunderturd doing donuts ! ! !
    I'll post more Pix when I get back to work.
    Thanks for the interest.
    VR&C. (Mark).
  29. James D
    James D
    Here you go. Just for fun.
    chryslerfan55 and DougO68 like this.
  30. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Hey James D. Thank for the inspiration. That PS image looks great. It'll help light a fire under my tailfeathers.
    Thanks,
    Mark.
