Projects "No Quarter"- '27 T coupe project
Discussion in 'Traditional Hot Rods' started by SinisterCustom, Oct 22, 2008.
  1. SinisterCustom
    SinisterCustom
    Front suspension mock up....
    Bone's are drilled for OG Ford perches to insert and will weld in. Axle mounted in front, kinda suicide, I guess....to help get the front a little lower.
    Also set the engine in place...just 'cause I couldn't resist....:D
    Once I get the engine and trans mounts made and their weight on the front end, I'll finish welding up the front and cleaning things up....then to the rear.:)
  2. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Lookin' *****in' man ,,keep the progress pics comin' ,,been there done that ,,,here's mine i did 5 years ago ,,,"go man go" !
  3. Chris
    Chris
    Looks rad! Looks like them perch pins worked as well for you!
  4. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    i have a nice set of buckets from an 80s chev van you can have
  5. Oldskool27T
    Oldskool27T
    from Tyler,Tx.
    That is going to be sweeeeet keep us posted.
  6. langy
    langy
    Missed this before but got here in the end :), looking forward to seeing your progress.
  7. SinisterCustom
    SinisterCustom
    They did....thanks again fro sending them to me.:D
    Cool, I'll have tio check 'em out. Thanks!
  8. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    Nice progress shots!
    Do you know what rearend your gonna use? How are you gonna set it up? What's your plan for the trans?
    I will have to come by and check it out sometime!
  9. Alienbaby17
    Alienbaby17
    Great build! Great direction! I think you've got it nailed.
    Looking forward to more progress pictures and updates.
    Jay
  10. SinisterCustom
    SinisterCustom
    Stop on by, just give me a heads up to be sure I'm home.....:)
    Rear end will be an 8.8 with 3.27 gears with transverse spring and P&J ladder bars. Transmission will be a Muncie M-20.....fully polished.:eek::D
  11. SlowandLow63
    SlowandLow63
    from Central NJ
    So that's what you've been up to. Cool man! Wacky 60's paint scheme planned for it????
  12. SinisterCustom
    SinisterCustom
    Define "wacky"......haha!:D
    The "plan" for now is blue metalflake frame with white pinstriping. Same blue flake on dash...white accents, vinyl, etc....
    Body??? Not sure....mild....maybe a satin blue with candy blue fogs.....or white with light blue fogs, not a big fan of white, but alot of '60's show rods were white....whatever will hide some of the many s****es and bruises this old body has...
    But who knows....still to early to tell what I'm gonna do....haha!
  13. sodas38
    sodas38
    Damn, I have one in my garage right now that I keep lookin at thinking I should build it. Body is a hair rustier than yours. So far your thoughts on the build are looking sweet!!
  14. Had to subscribe to this one, I need to get the one I found bought and home. Great looking ride. Nice pics also.
    Brad
  15. Jettback50
    Jettback50
  16. boo
    boo
    from stuart,fl.
    have one in my garage also,collected all the parts, flathead,39 linc. trans,columbia rearw/4.11 grs.,mor drop axil,mdl, A frnt 1/2 frame.16''wires rear,18''frnt 38 tk. grill shell,.gonna be 70 next year, hope i live to finish some of my projects.....
  17. rob lee
    rob lee
    from omaha,ne
    No time like now,sounds like a hell of a pile of parts.Get on it times a wastin;) Good luck & have fun!
  18. E.C.
    E.C.
    from Tx
    any updates ??
  19. irv0004
    irv0004
    This thing is NICE! I'm getting anxious for my T coupe to arrive here in Aus, I had an idea of a very similar build to yours.. Looking great with that front sweep and axle setup, and I love the dash! Keep it comin' :)
  20. clubcoupe37
    clubcoupe37
    nice score! cant wait to the progress on this one. I love T coupes. I have been looking for a decent T sedan body for a while myself.
  21. SinisterCustom
    SinisterCustom
    Fresh paint....
    Light met. pearl blue base, blue flake, and some sparklecence blue fogged along edges....
    Next is to polish all the aluminum, including the bellhousing and transmission.....after mocking it all up in the ch***is.
    brEad likes this.
  22. Chris
    Chris
    Looks good man, love the Roto-faze!!
  23. SinisterCustom
    SinisterCustom
    Thanks Chris...
    Still looking for an older Roto-Faze with the two side caps....but this one is pretty cool too...
  24. SinisterCustom
    SinisterCustom
    Mounted the rear ladder bars today, cleaned off the extra **** from the 8.8 and tacked 'er in....
    Also boxed the front frame area and installed new kingpin bushings in spindles. Hubs are at the machine shop being turned to fit Buick drums....(psst...Wayne, are they done yet?) :D
    If all goes according to plan, this should be the stance/ride height.....
    Hope to have it rolling in another month or so and push 'er outside for a better look...then pull body to finish welding up the frame.:)
  25. moses
    moses
    looks like another killer project in the works...jeffrey
  26. SinisterCustom
    SinisterCustom
    Made some motor mounts today.....
    Cut the backs outta some Chevy truck mounts for the block plates, welded some s**** tubing to it and added a little gusset. The mount will use a urethane bushing.
  27. fiftyv8
    fiftyv8
    from CO & WA
    Excellent work...
  28. SinisterCustom
    SinisterCustom
    Slight progress.....floor boards...
  29. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    Ha, you need to get those Buick drums on there!
    Lookin sweet!!
  30. 35mastr
    35mastr
    from Norcal
    Great progress. Floors look good too.
