1959 f100 build
Discussion in 'The Hokey Ass Message Board' started by 510madmav, May 13, 2010.
  1. 510madmav
    510madmav
    Figured I'd start a new thread of my '59 build. It's not going to be anything crazy, just a nice lowered driver..I'm sure all the fridge boys will like watching the progress of another 57-60 resto-mod. So here it is..
    1959 f100, all original, bone stock, 223ci 6cyl, 3 on the tree, short bed, small window. The truck was built at the old milpitas/san jose plant.
    Here is a pic of when i brought her home,
  2. 510madmav
    510madmav
    Here are some pics of it, with bumpers and other items removed.
    I also picked up some Firestone bias ply rubber, 7.10's in the rear, 7.0's up front. stock 15" steelies, My dad sandblasted and painted them one at a time at work..
  3. cjmac
    cjmac
    already starting to look cool !!
  4. conormulroney
    conormulroney
    Looks better with the WWW's. Good luck with that roof!
  5. 510madmav
    510madmav
  6. zimm
    zimm
    from iowa
    very cool to bad about the rust
  7. 53olds
    53olds
    Looking Good!
  8. 510madmav
    510madmav
    anyone have any pictures of what Sids tie rod drops look like installed?
  9. No_Respect
    No_Respect
    from So-Cal
    Love the truck! What is your plans with the roof? No pics of the Motor?
  10. jalopyshots
    jalopyshots
    You live in sunny Cali. Cut the roof off.
  11. 510madmav
    510madmav
    I'll take some pics of the motor today, I have plans to repair the roof with a solid donor cab.
  12. Redlined
    Redlined
    from SoCal
    I like the start.
  13. Javier
    Javier
    congrats on the project.have fun and good luck
  14. jd55f100
    jd55f100
    from alabama
    good start...........
  15. No_Respect
    No_Respect
    from So-Cal
    San Lorenzo is in the cold bay area
  16. Kickstarter
    Kickstarter
    from NC
    If you have a donor cab, it would be the perfect time to lower the top a little.
  17. Lone Star Mopar
    Lone Star Mopar
    My buddy has a 59 those trucks are tough as hell. Good luck with your project !!
  18. 510madmav
    510madmav
    Today, I got the other rear wheel mounted. And also ground out all the bondo that was in that quarter panel.
    Engine pics.
    new ignition, cut my own wires.
    Can somebody help me identify this carb? Is it a motorcraft 1100?
  19. Good start except for the roof. Do you have a doner cab yet? Someday you will need a Y-Block in it you know. :D
  20. 510madmav
    510madmav
    I'd love a 292. this 6 will work for now.
  21. Freeland
    Freeland
    looking forward to following this thread...
  22. 510madmav
    510madmav
    Can anyone tell me if a 56 f100 drop axle would fit 57-60 f100??
  23. VonMisfit
    VonMisfit
    from Alabama
    not that i know of
    time to call sid
  24. 57FORD
    57FORD
    im sure you can because the 57-60 front axle will lower a stock 56 one inch.
    you might have to widen the holes out for the 57-60 leafs but i think thats about it.
  25. 57FORD
    57FORD
    just remember if the 56 axle is meant for lets say 3 inch lower. it will only lower the 57-60 2"
  26. 510madmav
    510madmav
    Thanks for the info guys, just wondering because there is a 3" on CL locally right now..
  27. EZrider
    EZrider
    from Waco, TX
    '53-'56 axles WILL interchange w/ '57-'64 axles.
    same frame widths,
    same spring widths.
    spindles ARE different though, king pin diameters are the same, but the method of attaching the steering arms ARE different.
    '53-'56 arms bolt thru the spindle w/ 1 large bolt/nut.
    '57-'64 arms bolt to the spindle with the brake backing plate bolts.
    I actually have a '57 - up axle under my '56 panel, with later twin I beam spindles
    (again same KP dia) so I could have LARGE drum brakes; but the pin bosses are further apart so you need a spacer between the axle & the spindle pin boss.
    I can post pix, if you need.
    Bob Davis
  28. 510madmav
    510madmav
    Thanks Bob, that's useful info, Don't think I'll be pickin up that 56 axle. I'll probably just go with a More-drop axle before he shuts his doors for good, since He's local
  29. 510madmav
    510madmav
    Got another WW on.. I know i had said it was 7.0's in the front, but I forgot that they're really 6.70's..They're kind of small lookin up front. But once I get it lowered it should look good, right? opinions?
