bodymen What part is the most boring for you.
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, May 20, 2010.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Right now In working on hinges ,
    I know you guys know that its all boring ,But I need some motivation......
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I am no body man so I dont know if my vote is going to count or not...But sanding ****s
  3. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Vonn your 100 percent right.......I dont know why guys are so afraid of it ,Mix the dough and spread evenly sand with longboard and then recoat entire panel till you have crisscross even sanding ,Low spots you can see or feel .Thats bodywork.....Chasing scratches is a different issue ,Easily remedied.....Yes Im that bored .I remember 20 some years ago ,I use to do cars all by hand longboard ....
  4. milwscruffy
    milwscruffy
    I'm in the middle of block sanding right now for the third go around, so I'd say block sanding.
  5. 117harv
    117harv
    I have only done a little paint and bodywork it is a mess fore sure, using your fingers and thumbs to sand in those tight little contures untill they are raw, ****S!
    BTW, the painter allways gets the credit for a bueatiful paint job, not the body man.
  6. lowelife
    lowelife
    All bodywork ****s.
  7. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I started this thread for encouragement ................I know you guys are right .....I was cleaning some squeegees tonight and I have cuts on my hands and that laquer thinner sure as hell burns in those cuts .Ill be back later mud dryed .3rd coat on 2 hinges .....
  8. Abone29
    Abone29
    Yeah that lacquer thinner will find those cuts.I'd have to say sanding also,but if you want it slick you gotta do it.
  9. aaggie
    aaggie
    All those hours of sanding and filling then doing it again are forgotten when you finally roll it out in the sun and see how good it looks. I'm painting my '40 Chevy now and it is taking forever or so it seems..
  10. Silhouettes 57
    Silhouettes 57
    Sanding, sanding, sanding!!!!
  11. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Painting is the most fun and scariest time ....
  12. skullhat
    skullhat
    i hate mixing paint
    skull
  13. chopt49
    chopt49
    ^^ x2 ^^
  14. RamblerClassic
    RamblerClassic
    Sanding is the most boring, not the hardest, but most boring.
  15. flamed34
    flamed34
    The big stuff is easy, it's the little detail stuff that can get tedious...especially when you think you're almost there, only to find a flaw you can't live with that results in grinding, dolly work, and completely re-working the panel.
    When working on a project needing a lot of work or with a lot of mods, I find the work piece will "disappear" on me after a while. I usually shoot a fresh coat of primer on at this point and start blocking again.....when I'm 98% confident, I'll shoot a coat of good automotive single stage black to find those last few flaws I'm missing. Sometimes I'm pleasantly surprised, but often I stand back and scratch my head and try to figure "how'd I miss that?"
  16. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I always use two different color primers Then block
  17. 39 All Ford
    39 All Ford
    from Benton AR
    Blocking with a longboard is fun, blocking jambs is fun, it just takes too long, :D especially when you get to the 400 paper.....
    I wear latex gloves whenever I am doing ANY kind of paint and body including sanding. I got sick of having cut up, busted up, dirty *** stained hands. :D
  18. smiffy6four
    smiffy6four
    Yep, latex gloves rock. Keeps stuff off your hands and the greasy mitts of the bodywork.
  19. bikersteve
    bikersteve
    gotta agree with everyone who said sanding is the most boring...it was when I first started thirty years ago and it still is....but all the effort you put into sanding and smoothing till it's perfect is what makes the difference between a good, great or fan-freaking-tastic finish
    and the gloves are the way to go...finally people don't know at first glance I'm a bodyman....lol
  20. HOTRODKID91
    HOTRODKID91
    I got to the point where i start wearing rubber gloves cause that **** hurts!! but just think faster you get it done the faster you wont have to deal with it!!!!
  21. carcrazyjohn
    carcrazyjohn
    from trevose pa
    The part I was working on earlier were the speedway budget hinges .There casted crudely and i had to weld the pin in .The head started spinning ,Id reply to the other guys thread about installing these hinges ,But Ive had enough of these hinges for one night ..... I just hope this weekend Ill finish a door ...............
  22. inliner54
    inliner54
    i enjoy blocking. but if you have to do it for days on end it gets old. tedious prep work in tight areas and fine detail work is hard.
  23. THE SURGEON
    THE SURGEON
    id go with sanding too.. i spent almost a week in a trunk one time, that was horrable, then i had to mask it to mock dried paint like the car had been dipped in the factory, think i might have nightmares tonight because of the thought..
  24. apound
    apound
    The most boring part? Waiting to get paid!
  25. bigdog
    bigdog
    Blocking primer-the most boring . Hated it even when I was working on other peoples cars and getting paid to do it. But I've got a buddy who loves it, says he just gets into some kind of zen meditation thing while he's doing it.
  26. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Use to know that feeling .I gave up working on other peoples cars long ago.Most of them were deadbeats....Now I stick to brake jobs and some mechanicals ,As a side job...
  27. zach from ny
    zach from ny
    from New York.
    I'm the solo prep guy for my shop right now. So 45-50 hrs a week is spent block sanding, soft blocking, scuffing, taping, bagging etc etc etc. All of my fingertips are burned through and ******, but I am used to it by now.
    I HATE cutting and sharpening body lines. High/low spots too....burn through primer, reprime, sand, find pinholes, fill with spot putty, burn back to body work again...UGH.
  28. 49ratfink
    49ratfink
    the worst is the final perfecting part. I like getting up to the first mud/ primer stage. maybe guide coat it and give it a couple p***es with the long board.
    beyond that I'd rather someone else did it.
    SPARKS NOT DUST... that's my motto.
  29. zmcmil2121
    zmcmil2121
    Yes it does, esspecially that "**** retentive" wet sanding for the perfect paint job. But when done right, it is absolutly gorgeous.
  30. nailhead terry
    nailhead terry
    Waiting on bondo to dry then primer then paint then color sand and buff !!and buff!!
