Desoto Hemi distributor Adapt / Modify
Discussion in 'The Hokey Ass Message Board' started by bk812, May 26, 2010.
  1. bk812
    bk812
    Customer finally got his eelco 6x2 intake in after a big ordeal and when I test fit it distributor was hitting intake. Well i did not want to grind on the intake as it was pretty thin on the back side and so i decided to lower the distributor to clear the log intake. Stock one needed gone through and i had this sbc mallory laying around so i cut it down and machined an adapter ring. It all worked out good and was not too much trouble. Just though i would share in case anyone else is running into this problem.
  2. Mr48chev
    Slick, take a fairly easy to find piece and modify it solve a problem I like the idea. Looks good in there too..
  3. Corn Fed
    Corn Fed
    Does the Desoto and Chevy rotate the same direction?
  4. Shaggy
    Shaggy
    from Sultan, WA
    Yup, and 318 mopar too
  5. bk812
    bk812
    This method should let you run a ton of different points or electronic distributors or magnetos that can be bought cheap in your desoto hemi. Damn now i think it needs a vertex.:cool:
  6. jtille
    jtille
    Good to know.....Thanks
  7. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    Do you know if a Desoto distributor shaft will fit into a 318 distributor and make it a simple drop-in? Bill
  8. rodrobb
    rodrobb
    from Sweden
  9. 73RR
    73RR
    Modify the intermediate shaft/gear ***'y and then all A-LA dizzys will drop in.
