Best carbs for a 3x2 on a 327?
Discussion in 'The Hokey Ass Message Board' started by Gleeser, May 26, 2010.
  1. Gleeser
    Gleeser
    from Taylor, MO
    I want to run a 3x2 setup on my relatively hot 327 that's going in a Model-A. Trying to decide which carbs to run on it. I'm wanting to make relatively high cfm as this motor is pretty heavily built.
    What kind of numbers can you get out of 94's & 2G's?
  2. RClark
    RClark
    I'd run 2g's. Well actually I do. They're cheap, easy to get ahold of and, when run progressive, easy to tune.
  3. Blue One
    Blue One
    from Alberta
    If you want performance then a Barry Grant six shooter with 3- 250 CFM Demon carbs would give you what you need.
  4. draggin'GTO
    draggin'GTO
    I'd opt for the Rochester 2GC carbs.
    You can run 3 of the small-base carbs and end up with about 600 CFM ('57 347 & '58 370 Pontiac Tri-Powers used this setup).
    Or run one small base in the center and 2 of the large base carbs for the end carbs and end up with about 750 CFM ('59 -'65 389 & '63 -'65 421 Pontiac Tri-Power).
    Run all 3 large-base carbs for around 800 CFM total (the '66 389 GTO & 421 Tri-Power big Pontiacs came this way).
    I'm using Pontiac factory setups for reference here since I'm familiar with them.
    Three of the 94s will only net you about 450-500 CFM total.
  5. 33_chevy
    33_chevy
    from TX
    Any one know what the cfm,s on 97's...I'm running 4 of em
  6. Gleeser
    Gleeser
    from Taylor, MO
    Thanks much man. That's helpful. According to the builder I want to be in the 650-700 range for this particular engine.
  7. uncle max
    uncle max
    Old original 97's run 150 cfm's. The New English 97's flow 162 cfm's.
  8. 33_chevy
    33_chevy
    from TX
    Thanks uncle max...
  9. chubbie
    chubbie
    my information says that the 2G's are 280 CFM, x3 is 840 CFM
  10. draggin'GTO
    draggin'GTO
    Small or large base?
    I've seen the '66 Pontiac Tri-powers (3 large-base carbs) listed by different knowledgeable sources at anywhere between 780 and 888 cfm for this unit.
    Either way, the 2G Rochesters should be the best way to get 700+ CFM.
  11. chubbie
    chubbie
    thats a small base 2G @ 280 CFM. 840 is a lot of CFM on 327 cubes, but works OK. some times its hard not to open them up between all 4 gears!
  12. Abomination
    Abomination
    I agree with not going with 97s or Holley 94s.
    I'd go the Stromberg WW/Carter BBD/Rochester 2G route - especially the latter, due to availability of off-t******lf 3x2 setup goodies.
    ~Jason
  13. Shaggy
    Shaggy
    from Sultan, WA
    I'm going stromberg 48's on my 283
    No reason (exept mabey space) you couldnt go newer style holley 2 bbls either
  14. rhpope
    rhpope
    2 bbl carbs flow rate are at 3.0 in Hg not 1.5 in Hg like 4 bbl carbs are rated so the comparison is wrong.
    4BBL Flow = 2BBL Flow / 1.414.
    For example: A 500 CFM 2BBL Carb actually flows 353.606 CFM on the 4BBL scale
    Roger
  15. bigsam63
    bigsam63
    Gleeser,i run the 2G's with the progressive from speedway works just fine.
