buildn' a 40 ford pickup
Discussion in 'The Hokey Ass Message Board' started by ntxcustoms, May 31, 2010.
  1. ntxcustoms
    ntxcustoms
    from dfw
    after busting my *** and being completely broke for 5 years the shop is finally starting to come into its on right. I have a good crew of guys working hard and the wife is pitching in with some of the office duties. Customers are coming in the door and we are getting getting our projects done. I guess I've been a good boy for awhile cause it seems that the Big Man upstairs has parted the clouds, shone some light, and blessed me with some free time and a little bit of money to boot. While it's there I'm gonna run with it as hard and as fast as I can and for once be able to build one for myself and the shop.
    I've been mulling over in my head about what to build and I orginally wanted to go with a 36-37 pontiac coupe. Really anything with the art deco styling would do and I was drawn to the custom/taildragger side of things. But, the more I thought about it, I came to the conclusion that building a truck would go faster, cost less in parts, and in my opinion be more fun to build. Now with a 40 ford I could have all the styling that is early ford and still be in a truck. The search was on....
    I guess things just seem to click in place cause no sooner had I started looking, this 40 popped up on CL. I immediatly dropped everything and hit the road with the trailer behind..
    This is what she looked like when we got her back to the shop.
    The truck was pretty much just the sheet metal and was sitting on a chevy frame. Within the next few days we had the truck apart and sent it through the blasting booth to remove all the rust and see exactly what I would be working with.
  2. ntxcustoms
    ntxcustoms
    from dfw
    After blasting everything was coated in PPG epoxy primer. I could see that the fenders were in great shape! the hood needed only a small patch and a few pinholes filled. I wish I could say the same about the cab, running boards, and bed but oh well its just metal:D[​IMG]
  3. Congratulations on having your shop doing good business, and having the time and $ to work on your new toy. Rarely do those two happen at the same time. I also like the idea of a cool shop truck better than a car..... Nice CL find!! That truck is CHERRY by Michigan standards, and alot of other places I bet too! I'd love to own it.
    James
  4. i like the 40 ford truck, cl***ic
  5. ntxcustoms
    ntxcustoms
    from dfw
    Since the truck didn't come with a frame I made a road trip to Kansas to see PJGarst here on the HAMB and picked up a couple of 36-40 frames. If you're looking to buy anything off of him I can give you my word that he's a stand up guy. When we got there (much later than planned) he had the frames stacked and wired together on the forklift.
    I stripped the better of the two frames down and fixed a few spots. I also had to cut off a few brackets since the frame was a trailer at one time in its life. Into the blasting room it went and when it came out we put a coat of PPG industrial line paint on it. It's a real light cool gray with a slight blue tint. It's gonna look ***s under the body.
    Sorry for the ****py cell phone pic...
    This is the block I'm planning on running. 52 8ba...RK Design is going to build the motor with plenty of umph and goodies bolted on. Ron is a flathead guru and if you need a motor put together in Texas I'd highly recommend him.
    I went to Pate Swap meet and meet Joe (Joe's Speed Shop) and Sid (Nostalgia Sid's). I bought a 33-36 drop axle and 42-47 drop spindels from them. As always top notch stuff.
    I felt like a kid in heaven as I bolted the front end up. I know that this one won't drive off this time.
    So I have a 4'' drop 36 axle
    42-47 dropped spindels
    56 F100 brakes
    stock spring with 4 leaves removed
    Since I removed the top most leaf of the spring pack (it just seemed like it only added height) I had to round out the leaf that was now on top to fit all the way flush with the cross member of the frame.[​IMG]
    You can just barely see the gap.
    I took apart the spring and had the leaves blasted, ground smooth, and liner installed. New clamps were used and pete and jakes shackle kit keeps it bolted to the perches.
  6. ntxcustoms
    ntxcustoms
    from dfw
    James, the shop goes up and down, but in the long run things work out. Sometimes you just got to jump out there.
  7. chaddilac
    chaddilac
    Keep posting! I'm watchin!!!!
    I might have to swing by the shop when I'm in Dallas next?? :D
  8. ntxcustoms
    ntxcustoms
    from dfw
    Ok lets do some sheet metal work. Now the cab needed just about everything on the bottom end and some one in its life cut the floor and fire wall out. The dash has holes along with the header/visor and the pillars are peppered with pinholes also. The cabs are the same from 40 to 47 so there's plenty of them out there. I could go get another one, but what fun would that be?
    Here's a shot of the rust around the window visor area
    And another.
    Let's make a patch panel.
    I start with a paper pattern. In this case I made the paper for one side of the visor from the top to the bead line, center point ( the center crease in the pic above) to where the panel curves up to meet the pillar. I transferred this to the same gauge of metal and cut out the piece. I wheeled some crown into it, then it was to the bead roller.
    I cut off the excess beyond the bead and tightened the bead with a t dolly and hammer. Which gave me this...
    X2 and you get this...
    Now make some bottom edges with window lip and...[​IMG]
    Now put them together for a test fit...
    I'll post more tomorrow of the finished panel and of the floors, rockers, and cab corners. One step at a time!:D
  9. ntxcustoms
    ntxcustoms
    from dfw
    typical cab corner rust through
    rust cut out
    inner cab patchs made
    installed
    outer cab corners installed
  10. 40FORDPU
    40FORDPU
    Nice work, keep us posted on your progress.
  11. hiboy32
    hiboy32
    from Omaha, NE
    that is some reall nice metal work. Looks like it should be a neat shop truck.
  12. JGRAFF
    JGRAFF
    thats really nice work and a sweet choice of truck. i built one a year or two ago. You have my hotrod blessing!!!!! keep on truckin'
  13. ntxcustoms
    ntxcustoms
    from dfw
    Thanks guys for the nice words! 40fordpu your avatar looks exactly like where I'm heading with the motor, except for one more carb.:)
  14. UnsettledParadox
    UnsettledParadox
  15. 40FORDPU
    40FORDPU
    I meant to ask what you were going to run for a power plant. Great choice, looking forward to your progress (and mine).
  16. 40fordtudor
    40fordtudor
    love those "standaard" front ends
  17. draggler
    draggler
    Praise thee for given her a new lease on life ! I had noticed her on c/l aways back !
    One things for sure i say she went to the right owner!
    Damn sure caught my attention .
    Id have to say great work ,,well deserved,,,and keep it up ,
    keep knocking that one outta the park !
  18. Martin_F
    Martin_F
    Awesome fab work, man!
    Keep going!
  19. JOECOOL
    JOECOOL
    Looks good ,I have one setting here just need a little motivation.
  20. pasadenahotrod
    pasadenahotrod
    from Texas
    Nice truck.
    Haven't seen early Ford dropped spindles before, how about a picture or explanation of the modification done to them?
  21. Ctm_motortrends
    Ctm_motortrends
    from Ontario Ca
    Very good Fab work I see why people keep coming back. Good luck with the truck and the shop.
  22. ntxcustoms
    ntxcustoms
    from dfw
    SOrry for the confusion, the steering arms are dropped to clear the tie rods...
  23. ntxcustoms
    ntxcustoms
    from dfw
    Thanks for the feedback guys!
    40 Joecool if you decide to sell your truck let me know.
    40fordpu-I like the standard front end also, I think that the wider chrome noses don't look right on the hood. I have the grill, mirrors, hood pieces, latch, headlight bezels, and handels at the chrome shop now...
  24. ntxcustoms
    ntxcustoms
    from dfw
    here's the completed header panel
    test fit and ready for final trim and welding
    I had to make the rockers which were very basic panels.
    The floor under the seat was wasted so we made it...
    That's about were I'm at now. I'll post more as I move along...I hope to have the truck running and finished within a few months, but we'll see how that goes.:rolleyes: Stay tuned....
    LOU WELLS likes this.
  25. Kool Project, I'm doing one as well. Mine will be my daily driver (when there's no snow). I will be watching this thread.
    Here's what mine looked like a month ago, I'm getting close to being able to paint the frame now.
    Later
    Eric
  26. ntxcustoms
    ntxcustoms
    from dfw
    anybody have pics of the mods they made to their frame for a t5?
    I searched and found plenty of good info but no pics, just looking for some ideas. I really wanted to keep the truck trad but I also want to be able to ride down the highway too.
  27. 40Standard
    40Standard
    from Indy
    nice truck, great bodywork. I could use a header panel for my project, wow!
  28. CW's40TPU
    CW's40TPU
    OOOOH this brings back some memories, stay with it, they're *****'n trucks!!! cw.
  29. BarryA
    BarryA
    Great project - subscribed!
    I have a very rotten 40 cab (doors are almost pristine though!!)and figured it's time to get started. Have a line on some front sheetmetal - The rest I'll make up. No frame either so I'm looking around for options - may need to go late model:eek:
    This thread is the final motivation needed to make a start on it! Keep those detail pics of the patches coming please - I'm going to be doing plenty of the same;)
    Thanks
    Barry
  30. ntxcustoms
    ntxcustoms
    from dfw
    Hey Barry, go check out wescottsauto.com for full frame dimensions for a 35-40 frame if you would like to take a hand at making your own. If you plan to run anything other than stock you could then easily make your own center section to match...
