Features 48-54 Chevy/GMC trucks! lets see em ALL!!!
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jun 19, 2006.
  1. paco
    paco
    from Atlanta
    That my friend is a kick *** truck.
    PACO
  2. dt50chev
    dt50chev
    Have had mine on the road for about a month and a half now. Here's a pic of it at the Roundup.
  3. paco
    paco
    from Atlanta
    Another keeper!!
    PACO
  4. Here's a 51 Chevy I did for my dad a couple of years ago. He had one when he was a young'n and I thought it'd be cool to put one together for him. He drives it about once or twice a month:)... I decided to go with the shop truck look since the paint was OK. I just buffed it and painted where I needed to, redid the wiring, interior, lotsa, lotsa, other stuff and a buddy did the sign work and striping...
  5. tomy2tone01
    tomy2tone01
  6. dt50chev
    dt50chev
    Tom, how tall are you that you needed to lengthen the cab of your truck?
  7. Here's mine - 51 GMC - work in progress...
  8. Old Roadster
    Old Roadster
    BAD *** truck. :cool:
    Quick question, What frame are you using, It looks like a S10 by the wheels are set in.
  9. Chevy53
    Chevy53
    Here are some pics of my truck. Stock frame, stock engine and four speed ******. All leafs but one removed in the back and three left in the front also with a 3" dropped front axel, and airbags to be able to steer.
    Thinking about swapping the whitewall radials to blackwall bias plys.
  10. Trucked Up
    Trucked Up
    Simply...........................:):):):)
  11. tomy2tone01
    tomy2tone01
    Im 6ft 4 310 lbs a big boy!
    Tom
  12. I extended mine 10 1/2 inches. there are some construction photo's on my website (nothing new yet) under SHOP TRUCK BUILD
    Sinister just did a drawing that lit a fire under my ***. should have back on the road in a month
  13. FatDaddy53
    FatDaddy53
    i just traded a 200 watt amp for a 50 3 window cab...... lookin fer parts lol
  14. FatDaddy53
    FatDaddy53
    found a 79 dually with a flatbed that moight be my ch***is anybody ran that combo frame and cab
  15. Trucked Up
    Trucked Up
    Original frame with a MustangII and a 4 link.
  16. Danimal
    Danimal
    FatDaddy, the 79 Ch***is is too wide for these trucks unless you can get some serious offset rims.
    79 heavy half underneath the latest victim.
  17. AntiBling
    AntiBling
    If you don't mind the tires sticking way outside the fenders...
    I'm not talking about the rear wheels, the front wheels. I've seen the swap done, and using stock wheels, the fender lip will sit right above the center of the tire.
  18. Danimal
    Danimal
    That's exactly what I'm talking about. The stupid tire sticks out about 1 to 1 1/2" beyond the fender. Note the difference on my 1 ton panel between the front with a '79 heavy half and the stock rear.
  19. PhilJohnson
    PhilJohnson
    My old 51 GMC. It was pretty good old truck. I racked up a few backroad miles on it last year. I wound up selling it (much to my Mom's disappointment). It was a 3/4 ton. Had the original GMC six in it which ran very well. I was pretty broke when I bought it. At the time I was making about 150 bucks a week and had to drive 40 miles one way to get to work. The fuel pump sorta worked. I wanted to get it on the road so I rigged up the setup below.
    It worked well enough but sometimes the engine would starve for fuel. I have no idea how many miles I put on with it like that. When I took the truck to the casino I got a lot of weird looks from people at the gas station. I guess they had never seen someone having to stand on top of a truck bed to fill their tank :D I think the truck had a top speed of 50 mph but I had no way of knowing for sure since the speedometer didn't work. A few more pics:
    I currently have a 52 Chevy 1 1/2 ton dump truck. It runs but needs some tune up work and brake work. Bought it mainly to haul logs and fire wood and the occasional load of s****.
  20. Grumpy
    Grumpy
    from NE Ohio
    Think you could get away with running a stock 1955 chevy 15x5 steel wheel? To try to tuck it in somewhat?
    Or ordering a 15x4 steelie from wheel vintique or somewhere similar?
    I mean, if you bought a truck already treated to that swap, maybe theres a way to mask the added width..
    I had a 54 Chevy 2dr sedan with a camaro clip. Was way too wide and dude had 15x7 wheels on it..it ****ed.
    I added 4x4 S-10 steel wheels up front with hubcaps and it looked really ok. They are ugly wheels, and theres no other choice but to run caps, but on a 54 with a more kustom vibe, it was the obvious choice..
  21. joethehuman
    joethehuman
    Here's my 53.
  22. TMoney
    TMoney
    Finally had a decent day out today. Got 'er out for the first time with new look.
  23. RDO_23
    RDO_23
    Here's my 52
  24. Ramblur
    Ramblur
    Heavy Hauling...
  25. paco
    paco
    from Atlanta
    Very nice RDO ... the visor makes it.
    PACO
  26. RustOutChevy
    RustOutChevy
    from germany
  27. hey can some one send me a few pic of the cab corner on a gmc ! please need to see if its true that its a direct fit to imternational ! thanks . jake . I love the hamb cuz i can almost garantee that a few people will come thro. thanks in advance
  28. cab corner on a '49 chevy 3100... I think it's the same as a gmc
  29. ilguy
    ilguy
    from Illinois
    Mine
  30. deuceV8
    deuceV8
    this one use to be mine.
