Is this a 9 inch?
Discussion in 'The Hokey Ass Message Board' started by maddog, Jun 2, 2010.
  1. maddog
    maddog
    from So Cal
    I am thinking this is a Ford 9 inch but the welded seam all the way to the backing plate is not something I have seen before.
    I am looking at this on Craigslist and I do not have better pictures yet.
    I'm sure it is not the rearend that came in this frame.
    Any ideas?
    Thanks
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Identification on an 8 or 9 inch Ford is usually done by showing the front pumpkin which has a separate pinion bearing flange which is shielded which makes the bottom two bolts on the 9" removeable only by open end wrenches.
  3. enjenjo
    enjenjo
    from swanton oh
    It's not an 8 or 9 inch.
  4. maddog
    maddog
    from So Cal
    Well there you go. You said that like you would know. I could tell easy if I could see the front, but I cant.
    Why are you so sure, what gave it away for you?
  5. If the rear of the housing is completly round and smooth it just may be a 8 3/4 chy. Can't see enought to tell !
  6. alumslot
    alumslot
    On a 8" you can take all the nuts off to pull the pig out with a socket on a 9" you CAN'T.
    Jim
  7. This isn't a joke but there is also a 9 3/8 (or something close) out there. I had one once, came out of a Lincoln if I remember right. The housing and axles are the same as a 9" but the center section is different. Good luck finding gears for 9 3/8". I can't remember how to tell the difference though....google might help. Hmmmm, I'm thinking the 9 3/8 had a horizontal strengthening rib on the carrier that curved down at the left end of the rib. More is coming back to me...there was the "mustang" housing and then there was a beefier housing that came in larger cars. The 9 3/8 would not physically fit inside the "mustang" housing, that;s how i came to find out about them.
    Check the bolt pattern, could this be a fifties Chev rear?
  8. gimpyshotrods
    gimpyshotrods
    The 9-3/8" rear only differs very slightly from the 9" rear. There is a small curved cutout in the flange where the center section mounts, in both places where the ring gear p***es by it, for clearance.
    You can put a 9-3/8" center section in a 9" housing if you grind it for clearance.
    You can put a 9" center section in a 9-3/8" housing with no trouble at all.
    As far as I know, and have seen, all of the 9-3/8" rears are 31-spline.
    They are otherwise indistinguishable from the 9", except for the wheel bolt pattern, which would be the "big-car" or truck pattern, not 5 on 4-1/2".
    That one looks like a Chrysler to me, from those angles.
  9. YYYYYYYY, No, Mopar.
  10. jerry
    jerry
    Mid 50's Olds/Pontiac.
    The housing construction and the hint of a rib at the left front . The flat style u-joint flange.
    jerry
  11. superbyrd
    superbyrd
    looks like 50's GM. also looks to be wearing aluminum drums.
  12. HOT40ROD
    HOT40ROD
    from Easton, Pa
    The house does not look like a factory 9 or 8 inch ford. But there are some co. building housing. I would have to see the front to make sure.
  13. DualQuad55
    DualQuad55
    from NH
    57-64 olds/pontiac.
  14. enjenjo
    enjenjo
    from swanton oh
    Rear of the housing is round, Ford is oval.
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    kinda looks Mopar-ish 8.75
    having a better look at the front will help..but as enjenjo says..not a ford 8 or 9
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    see the difference in the ford 8" here?
    before i filled the dimples
  17. draggin breath
    draggin breath
    a lincoln 9 3/8 housing will take a 9 inch chunk,but all I've dealt with a 28 splines and the Hollander agrees.
  18. Francisco Plumbero
    Francisco Plumbero
    from il.
    Im with the guy voting early GM, looks like an Olds pumpkin, Your'e gaming or you would have shown us the diff.
  19. maddog
    maddog
    from So Cal
    No game.
    I have emailed the seller but no response.
    I think for the most part most agree its not a 9 inch.:)
  20. Brad54
    Brad54
    from Atl Ga
    It's not a Mopar 8.75 either--Mopar housings don't have a welded seam running lengthwise on the tubes.
    -Brad
  21. 56oldsDarrin
    56oldsDarrin
    I am thinking pont/olds.
  22. Olds. The housing ends are a full circle. Mopar ends are flat on top.
    This Olds end from MW website:
  23. Kenneth S
    Kenneth S
    It's an old chevroldsmobuicktiac product, I'd p*** on it.
  24. Mike51Merc
    Mike51Merc
    I asked my wife the same question and she laughed at me.
  25. my olds housing has the same welded lines as this....
  26. FEDER
    FEDER
    All the 9 3/8 ford chunks out of full size mid 60s Ford and stationwagons I have removed were 31 spline and 5 on 4 1/2 boltpattern. The Lincolns of that era may be
    5 on 5. Fed
  27. Yeah, '61-'69 Lincolns are 5 on 5", In case anyone cares. I've never saw a 9 3/8" in any thing other than a Lincoln however, interesting.
  28. gimpyshotrods
    gimpyshotrods
    Circa 1965, the Continental had a Dana 53 rear, the forerunner of the Dana 60. It is indeed 5 on 5"
  29. Bearing Burner
    Bearing Burner
    from W. MA
    As far as I know the 9 3/8 only came in a 2.78 ratio. i was told they came in Ford Police Cars
  30. johnnie
    johnnie
    from indiana
    There are more for 9 3/8. Lowest ratio I have had was 3.50. They came in several mid '60s Galaxies, and similar cars.
