Anyone ever rod a long bed truck?
Discussion in 'The Hokey Ass Message Board' started by J Man, Jun 1, 2010.
  1. Don't see why not. You got to make the driveshaft a little longer, run a longer brake line to the rear, and run longer wires to the rear lights. Everything else is pretty much the same as building a short bed truck.
  2. IH TRUCK
    IH TRUCK
    from d town IL
    0414101504.jpg rolling this 40 IH long bed
  3. ShastaStyle
    ShastaStyle
    from Nor-Cal
    Here are a couple that I've come across and saved.
    kiwijeff likes this.
  4. OldSub
    OldSub
    I've done several long beds, starting with a '66 C10 back in the late 70's. For a number of years my daily was a '72 C10 long box. My favorite has been a very non-HAMB friendly '89 Chevy 1-ton 4x4 that I used to pull my trailer. It was both very useful and looked great. Sadly it lost out in an accident a few years back.
    My current project is a '54 GMC 1-ton which didn't come to me with a bed. The factory bed would be nine feet long. I'm keeping the full 137 inch wheel base and haven't solved the bed problem yet. I will NOT be shortening the truck because I'm building the truck to pull my trailer and I want both the length and weight in the truck.
    Here it is as it arrived home a while back.
    Today the cab is off the frame, it has a GM 14-bolt rear using the stock rear suspension, and the disk brake IFS from a '72 C20. A Cadillac 500/TH400 combo is nearby. You can't really see all the problems with this cab, but I have another I may replace it with and a 3-window Chevy that I might cut up to repair this one.
    I'm building this truck to tow my trailer and want it well equipped for that task. I'd use the factory 9-foot bed if I could find a good one, but suspect I'd need to modify it because I plan to use a slid-in utility box to carry tools and equipment. I do have some ideas how to make a 10 year old utility box look right on a more traditional truck.
    Another approach I've considered are modifying the utility box to look like tool boxes setting on a flat bed and simply hanging the steel edges from an old flatbed on the bottom edges.
    My favorite approach, but clearly the hardest and most challenging, is to make a pickup bed based on the side panels from a similar year 1-ton panel. It would have a cl***ic look but also be smooth sided. I have a parts panel I can use but am unsure if I'm willing to commit to the sheet metal work.
    So yes, I've run several and my next finished project will be yet another one.
  5. lazy j
    lazy j
    Here's my '49 longbed 3/4 ton, has 1/2 ton suspension now
      497.5 KB
  6. 100% Matt
    100% Matt
    I think rake makes it or breaks it with long bed styleside/slab side trucks. Personally I prefer a little forward rake. I'm installing a 2.5" drop axle on my truck next week for that reason.
  7. 100% Matt
    100% Matt
    thats cool!
  8. magsnubby
    magsnubby
    from Fresno,Ca
    Why would anyone build a long bed?
  9. tjelwood
    tjelwood
    from oklahoma
    My 50 is a longbed F2 now with half ton stuff. Have a couple of pics in my profile, but I don't know how to post them using my iphone.
  10. 510madmav
    510madmav
    Thats good lookin!
  11. dt50chev
    dt50chev
    Mine (in my avatar) started life as a 3800 one ton with a 9 foot bed. I cut 30" out of it and made myself a short bed. 9 feet is just way too long.
  12. turdchazer
    turdchazer
    from Spokane
    Heres Norm Grabowskis long bed hot rod...
    I love the front bumper it's carved with "Boogie till you Puke"
  13. terd ferguson
    terd ferguson
    Thanks! I sold it to a hamber in The Netherlands.
  14. flynbrian48
    flynbrian48
    Total waste of time... Nobody should build a one ton either.
  15. onlychevrolets
    onlychevrolets
    at the shop we are building a 53 International long bed for a customer, I'll get some pictures, We put a LS1 and 4L60 transmission it should haul ***.
  16. flynbrian48
    flynbrian48
    You too, huh? ;) The DT above has a 6.0 (LQ9) and 4L60E with 4.10's in a Dana 70. I'm expecting adequate (as Rolls Royce used to advertise) performance. :D
  17. roddinron
    roddinron
    Huuuuuhhh?
  18. Mr. Jean
    Mr. Jean
    I've had both and think they they each serve a need.
    Have a short bed now, but no interest in getting a goat thank you.:D
    Here another one I've owned.
  19. Pooch
    Pooch
    from Oklahoma
    My bed is long
  20. 100% Matt
    100% Matt
    A couple more:
    Javier's truck before the new paint
  21. Brahm
    Brahm
    I have not, but I'm in the process of it. My 52' Chevy is a long bed.
  22. ELDANGEROSO
    ELDANGEROSO
    I'm almost done with my 59 Chevy 1/2 ton Longbed fleetside, will post some pictures when done....Sure is alot of Late 50's long bed fords running around here. Wish somebody would post some 58-59 chevy fleetsides.
  23. J Man
    J Man
    from Angola, IN
    If I had one like that without a bed, it would get a flat bed. It would have to be a dually though to look right.
    I actually have a motor home ch***is in the barn looking for a body.
    The one I have that this post id for is a '54 3/4 ton. It is so solid I do not want to do any cutting on it.
  24. Danimal
    Danimal
    I've still got that original '54 flat bed. I'd swap you for your bed sides. I also still have that '54 cab and big nose...and a '49 complete cab and short bed and S10 long bed frame and fenders. I'd swap the whole '49 for that 3/4 ton.
  25. OldSub
    OldSub
    My objectives for this specific truck make a simple flatbed the wrong answer on it.
    I own several flatbed trucks and having one more would not do anything I need to do. I also have a '54 GMC 1-ton dually Hydra-Matic truck. One of my visions of it finished is with a simple flatbed. In that approach it looks and basically is stock and isn't worked but rather is shown.
  26. J Man
    J Man
    from Angola, IN
    I would honestly rather just sell it. I want to get going on one of the Ts and I have a hankering for a mid to late '30's sedan. I just figure if I can't sell it I might start messing with it.
  27. cj92345
    cj92345
    from so-cal
    mine
      390.3 KB
    falcongeorge likes this.
  28. mungle
    mungle
    Not sure if my Elcamino is considered a long bed.but here's one of my 60 Appache
  29. nwaringa
    nwaringa
    Mine when I started.... workin' men didn't need no stinkin' short beds in the 50's.
