Pete & Jakes Hydraulic Clutch and Brake kit 33-34?
Discussion in 'The Hokey Ass Message Board' started by choppedsled, Jun 4, 2010.
  1. choppedsled
    choppedsled
    from Spokane WA
    Hello, looking for feedback on Pete & Jakes under floor hydraulic clutch and brake kit, non-boosted. I'm considering installing one in a stock 34 Ford frame. Any input, pics, or recommendations of a simular unit?
    I may also go the Ch***is Engineering route with thier x-member, but have read about the interference issues involved with fitting thier clutch with thier x-member. Doable but am looking for the least painfull option if there is one.
    Many thanks...
  2. chuckh
    chuckh
    from wy
    i had that setup mounted to frame. had to trim x-member a little. my early chrysler hemi bellhsg. interfered w. the brake pedal so i went w. ansen swinging pedals and early 60,s chev. p.u. master cyl. i could,ve made it work but floorpan and trans tunnel would,ve taken more work
  3. choppedsled
    choppedsled
    from Spokane WA
    I like that early chev master, have one in the shop. Was/is a popular way to go. Vern Tardel sell a nice pedal setup to use one.
  4. chuckh
    chuckh
    from wy
    ya i bushed the clutch side down to 3/4. keeps the pedal effort down and t.o. brg. from overextending
  5. coopsdaddy
    coopsdaddy
    from oklahoma
  6. I've used two, both in a 32' ch***is with flatheads. They were frame mounted and worked fine.
  7. Idaho/Dave
    Idaho/Dave
    from Idaho
    I've got one in my 34, everything works good
