Av8 transmission mounting
Discussion in 'The Hokey Ass Message Board' started by RoadWarrior13, Jun 5, 2010.
  1. RoadWarrior13
    RoadWarrior13
    from Louisiana
    I am getting read to mount the tranny.. is it necessary to have a tranny cushion between the chasis and the mount ... i should be able to get something from another car and make something custom ?
  2. RoadWarrior13
    RoadWarrior13
    from Louisiana
    And what does the original look like
  3. doctorZ
    doctorZ
    yes, you'll want rubber to insulate it. what transmission are you running?
  4. RoadWarrior13
    RoadWarrior13
    from Louisiana
  5. doctorZ
    doctorZ
    the model A transmission had a cast mount that went over the lip of the center crossmember. you will probably have to clearance the center crossmember and after that you just need tabs flanking the tail shaft with stock mounts on them.
  6. bbanks12
    bbanks12
    heres the brackets i built for my mount. be sure to brace back to tie the whole crossmember together as well, in stock form its kinda flemsy
    If your looking for a place to attach your rear sway arms this is a good place to do it as well. the plate just below the transmission mount bolt is where mine is attached, you just cant see it with the linkage in the way
      74.3 KB
  7. RoadWarrior13
    RoadWarrior13
    from Louisiana
    show me your brake and clutch pedal mount
  8. bbanks12
    bbanks12
    ill have to get some pics tomorrow at the shop, but i took the pedal shaft from my A transmission and welded it to a plate which is then welded to the frame. the linkages still need some touch up work lol, but it is all working perfect. get pics to ya asap
  9. doctorZ
    doctorZ
    you can also brake some 12/14 gauge and turn the crossmember into a k-member and just use a set of 1939 ford pedals. you won't have to do much to them besides heat and bend them in since they are going in a much narrower car than they were designed for.
  10. bbanks12
    bbanks12
    here ya go. like i said, still needs some touch up work, but everythings in its place. let me know if you decide to go this route and need some more help
    btw the big straight linkage goes to the brake cross shaft, im still using the mechanical brakes. its alot of work to get clearance for the brake cross shaft
      172 KB
