Removing model A firewall
Discussion in 'The Hokey Ass Message Board' started by MEYER8821, Jun 5, 2010.
  1. MEYER8821
    MEYER8821
    Hey guys so I am trying to remove my Model A's fire wall so I can recess it so my engine will fit in there nicely. I am having a heck of a time tryin to remove it, so far I have drilled out all the hold screw/rivet heads that I could find. The top is free but the sides are stuck in there, its almost like they have been clued in. Does any one have any good ideas on how to get it out in one piece? I have searched through the forum but was un-able to find what I need.
    Thanks in advance.
  2. flatford39
    flatford39
    It is spot welded to the cowl panels. You can try to carefully sawsall them out or drill them out and weld the holes up later.
  3. rodger6494
    rodger6494
    I had something really similar happen when working on my 29 rpu.I found small welds on hidden spots after,like you,I drilled out all rivet heads.I would suggest getting in there with a small flat screwdriver and try to gently pry to find out if you have said welds.
  4. squarebird352
    squarebird352
    I recomend drilling the spot welds out, then go back and plug weld them back in. easy on the heat. thats what I did on my buddy's r.p.u.
  5. Hit the flange with some 80Grit on a block lightly and the spot welds will appear.
  6. MEYER8821
    MEYER8821
    Hey thanks guys! they must be pretty hard to see becuase I never saw any. But I will go out there and see what I can do. There is a primer on the body so that might be hiding the spot welds.
  7. MEYER8821
    MEYER8821
    Hey thanks guys, so I sanded away the primer paint and I was able to see the welds. I drilled them out and the firewall came out no problem.
  8. are you reversing it?
  9. MEYER8821
    MEYER8821
    I have not quite decided yet, but I am leaning towards it.
  10. chopo
    chopo
    i was thinking of this also.... would the original fuel tank need to be altered to reverse the firewall?
  11. MEYER8821
    MEYER8821
    I am not 100% sure yet, but it looked to me like if you are going to keep the gas tank in the car you might have to cut a portion out of the front of the gas tank.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Did it the same way removing my 28's firewall..worked fine
  13. djust
    djust
    from Oklahoma
    Getting ready to do the same thing this week end thanks for the question.
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
  15. pprather
    pprather
    I believe the reversed firewall will fit with the original tank in place on the '30-31.
    Not a great picture, but you can see the ribs are reversed and this owner has told me he runs the original tank. Still has a dimple for the distributor.
  16. Crusty Nut
    Crusty Nut
  17. 1931fordtruck
    1931fordtruck
    I removed all the screws, rivets, and drilled out the spot welds on my 31 truck. The firewall is loose at the top, but not at the bottom. Does anyone have any suggestions, or have ran into the same problem?
  18. ThirtyFordor
    ThirtyFordor
    from Wisconsin
    Is reversing the firewall the best way to go? Or is it easier to cut out what you need to make room. Does it look the nicest? Opinions?
  19. More spot welds to find, they also can mate for life and need some persuasion
    Yes to all. It becomes personal preference.
  20. F-6Garagerat
    F-6Garagerat
    Check out my firewall recess in my build thread. I was able to do it without losing any toe board.
    IMO, model A's are supposed to have that rounded shape firewall edges. Doesn't look right reversed and it's not as easy as just flipping it around and welding it back in.
  21. MATACONCEPTS
    MATACONCEPTS
    Food for thought: Use an Electric SBC Water Pump mounted & plumbed to a piece of angle iron mounted under the car or ??? Plumbing it with some copper tubing will give you extra cooling where you could get away with no fan.
  22. Frenchy Dehoux
    Frenchy Dehoux
    Great idea if you need more room for your engine to fit.
    Frenchy
  23. Tsquared
    Tsquared
    from Pratt, Ks.
    yes yes yes!!! you will be able to see them. If you have a new sharp 1/4" drill bit you can usually drill from the outside into the spot weld just far enough to cut out the weld, without drilling clear through the firewall.
