Model A firewall reversed?
Discussion in 'The Hokey Ass Message Board' started by tahern, Jun 7, 2010.
  1. tahern
    tahern
    from Kentucky
    I'm wondering about reversing the firewall to get some more room, anyone done this? pictures would be great thanks Terry
  2. madpole
    madpole
    seems to work well on a 30-31. i have seen it done, but dont have any pics. i am sure someone will share some.
  3. To my knowledge, it's a fairly old hot rod trick that's been around for decades. I've always liked the look a Model A with the firewall flipped. Here's a link to a recent build, Seret's Orange Jalopy Coupe with the firewall flipped. Hope that helps you out.
    http://www.jalopyjournal.com/forum/showthread.php?t=478581
    Image from Seret Speed & Custom
  4. tahern
    tahern
    from Kentucky
    Thanks Payne, just what I was looking for. Terry
  5. The37Kid
    The37Kid
    Someone here on the HAMB has a really great one, reversed, but they keep the original 2-3 inches of the stock firewall. You really had to be into Model A's to catch the fact that it was swapped. Wish I'd made a note of who did it.
  6. Canuck
    Canuck
    Probably as many ways of doing it as there are people reversing a firewall.
    This is my version. Drilled out the spotwelds holding the firewall in. Also had to recess a area to clear engine. The biggest problem was modifying the areas that come down to the frame on each side, especially as I wanted to keep the forward frame mount bolt. A bit of shaping and welding and it is a go. Moved the recessed area back about 4 inches and kept the raised beads from the original. The sides of the recess were rolled with about a 1 inch diameter roll were they weld to the firewall and the recess.
  7. Jethro
    Jethro
    This is my 30 firewall
  8. Crusty Nut
    Crusty Nut
    Here is mine. I turned the the whole thing around except for the feet.
  9. lrs30
    lrs30
    from Kentucky
    What and where is the tank are you running?
  10. gasserjohn
    gasserjohn
    kept top part &made steel firewall to support pedals mastercly
    did it in 67
  11. Seepwater
    Seepwater
    You have to be careful...all the holes go the wrong way :)
  12. Crusty Nut
    Crusty Nut
    If you are talking to me, it is a '32 tank mounted out back.
  13. Lots of nice work in this thread.! I am working on a reversed 30 in a 28. Not to a point yet where I can take pics.
