How Do I Remove This?
Discussion in 'The Hokey Ass Message Board' started by 64ville, Jun 3, 2010.
  1. 64ville
    64ville
    from So Cal
    I've been trying to remove the end piece of my shifter and have tried pulling it out and un-screwing - no luck. I even tried un-screwing and pulling at the same time but the damn thing doesn't want to budge. Has anyone tried and successfully taken one off a '64 before? If so, I'd appreciate some guidance on this. I attached a picture of it below.
  2. Look for a set screw.
    other wise a pair of channel locks and a rag are in order.
  3. 1941ihkb5
    1941ihkb5
  4. froghawk
    froghawk
    It's been awhile, but as I recall the shift levers on the GM cars I had, from '59, '61 and '65 Pontiacs and '63 and '66 Buicks, seemed to be one-piece, including the stylized end.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    One piece you have to cut it off! Sorry I wish it was easier.
  6. tommy
    tommy
    Look for a pivot pin. It will probably need to be driven up from underneath. The pin will be in the painted collar that rotates when shifting to different gears. The chrome lever usually rotates around that pivot pin when you pull it toward you before you shift out of park. It's hard to see in your picture.
    Vice grips and hammers can do irrevocable damage to pot metal parts before you realize what went wrong. Be careful if you want to reuse the column. It's very easy to ruin a perfectly good column.
  7. Long Roof Larry
    Long Roof Larry
    My 66 Ford Galaxie had one like this. It swivels and you would think it screws on or has a pin or screw holding it on. It didnt. I had to cut it length wise on two sides to remove it. It seems to have been pressed on the end of the shifter rod with what looked like "barbs" holding it on and in place to swivel.
    Hope this helps.
    Larry
  8. 64ville
    64ville
    from So Cal
    Thanks for all the info guys. I checked for set screws but couldn't find any. I think the only way to get it off would be to actually cut it, which I don't to do. I'll see if there any other ways of pulling it off.
    Thanks again.
  9. rlowrod
    rlowrod
    from Corona Ca
    the plastic ones are molded on and the metal ones have a press fit snap lockring in them sometimes you can pry them off, but you got to be careful. I have never been able to "pull" one off. I generally cut them off and make a custom one on my lathe.
  10. Nah use a cutting torch lol
