small period correct quiestion
Discussion in 'The Hokey Ass Message Board' started by trestles126, Jun 9, 2010.
  1. trestles126
    trestles126
    so im gettin a canvas button on top made for my 29 late 40s style banger RPU.... the guy at the upulstry shop talked me into running 2 safety attatchments at the front too corners underneath the bedrail(all buttons will be just under the bed rail ledge so the canvas is pulled over the sides and buttoned. the 2 buttons up front are in case the canvas decides to unbutton at the high rate speed of 55 mph the banger does :)
    just a silly question but something as simple as these 2 buttons throw the car off in your guys opinion
  2. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    Doubtful that anyone would fault you for a safety measure like that. They aren't that obvious, are they?
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Those fasteners have been available since the Model T days, it isn't a problem.
  4. trestles126
    trestles126
    thanks for the info guys...gettin it done friday or monday should come out clean and be usefull
  5. mj40's
    mj40's
    Good idea, believe your upholstery guy!
  6. trestles126
    trestles126
    sorry for the poor gramar :)
  7. doctorZ
    doctorZ
    *grammar
  8. stanlow69
    stanlow69
    To be absolotly correct- use slotted screws, not phillips- but they are covered up anyway.
  9. denis4x4
    denis4x4
    from Colorado
  10. trestles126
    trestles126
    i actually riveted everything in....not sure if thats correct or not haha
  11. trestles126
    trestles126
    i was being sarcastic :) im not a dumb crane operator for nuthin
  12. Yes, and you will thank him for them. Buttons don't always hold in a crosswind and such!
  13. propwash
    propwash
    from Las Vegas
    those things were used on European roadsters way back when - used on boat and aircraft covers and tonneaus even before the turn of the 20th century. If you're really that concerned about "period perfect", you're good to go.
    dj
  14. Fenders
    Fenders
    And to be period correct be sure to use a single pot brake cylinder.
  15. trestles126
    trestles126
    thanks guys getting it made on tuesday hopefully
  16. KrisKustomPaint
    KrisKustomPaint
    I've used those on teen cars. they are more period correct than the snaps anot that snaps weren't around but the twist locks were more common, you can get long shank ones so you can have 2 or 3 different pieces lock on at the same point.
