1955 chevy truck amp meter
Discussion in 'The Hokey Ass Message Board' started by 60 chief, Jun 8, 2010.
  1. 60 chief
    60 chief
    I am trying to hook up a new gauge cluster for a 1955 chevy truck second series and I cant figure out how to hook up the wires to make it work any help would be appreciated.
    Thanks David
  2. Torkwrench
    Torkwrench
    Do you have a shop manual for your truck? If not, get a FACTORY Chevrolet shop manual, not a Chilton's, not a Haynes, not a Motor Manual. The factory Chevy manual is available in reprints, and is very well written and illustrated. It is also MUCH easier to read and follow than shop manuals for new cars and trucks. In addition to the wiring, it will help you out with any other part of your truck that you may have to work on...engine... suspension... sheetmetal...etc.
  3. 325w
    325w
    Stock type cluster ? After market gauge cluster ?
  4. terd ferguson
    terd ferguson
    Here's the wiring diagram from the factory shop manual. I can take a look at mine tomorrow if you need more help.
  5. 60 chief
    60 chief
    It is a stock gauge. The shop manuel I was looking at showed the 12 ga. red hooked to the top screw on the regulator, and a 12 ga. black ran to the ground on the starter. I tried this hook up and I think it was a dead short, the coating on the wire instantly got so hot you could'nt touch it.
  6. BOWTIESR2
    BOWTIESR2
    from GREELEY CO
    Black wire should go to battery cable terminal on starter...........
  7. 60 chief
    60 chief
    That is where I hooked the black wire, where should the red wire hook up and does it only need two wires, there are four terminals on the amp meter.
  8. 60 chief
    60 chief
    I hooked the black wire to the ground on the starter should I change it to the positive on the starter.
