Disk brakes on 53 Chevy pickup
Discussion in 'The Hokey Ass Message Board' started by OldCarPilot, Jun 14, 2010.
  1. OldCarPilot
    OldCarPilot
    from Bel Air MD
    Has anyone done this using stock parts? Rather than buying a $500 kit?
  2. 454navyss
    454navyss
    im going to be doing this soon....using an s10 frame with stock s10 disc brakes
  3. OldSub
    OldSub
    Yeah. I paid $100 for a bracket kit and then spent at least $400 more on new parts to feel good about my brakes. It was long enough ago I no longer remember what I spent total.
    You really need to convert to a dual master at the same time, which means you'll be re-plumbing at least part of your brake system.
  4. OldCarPilot
    OldCarPilot
    from Bel Air MD
    I have a dual power setup in there now, but its drums, and I'm not liking power with manual adjusting brakes. I can get parts cheap so I just need to know what parts from what car/truck I need to look for.
  5. 55 dude
    55 dude
  6. 41PICUP
    41PICUP
    I used an ECI kit, wasen't that much.
  7. OldSub
    OldSub
    I used '73 Chevelle rotor and caliper and outer bearing on mine. The inner bearing with seal and a sleeve that went on the spindle, along with the caliper bracket all came in the $100 kit.
    The kit said mid-70's mid-size GM, I chose '73 Chevelle because I was already using a '73 Chevelle rear. Master is the same car too. All the brakes parts were new when I put it together. Brakes are too important to cheap out on used parts. And they don't cost that much anyway.
  8. OldCarPilot
    OldCarPilot
    from Bel Air MD
    I found a kit on ebay that is about $280 + $70 shipping. Probably can't do it for much cheaper, but if I know what parts these are I can spend the money over some time. I get a pretty good discount from my parts people.
  9. Master of None
    Master of None
    The dreaded Speedway motors sells a nice kit that I installed on a customers 50. It bolts up well but does require you to run 15in rims that are for disk breaks.I also converted to a duel reservoir master at the same time.
