History Official B Altered Truck Restoration Thread
Discussion in 'The Hokey Ass Message Board' started by VA HAMB, Dec 15, 2009.
  1. VA HAMB
    VA HAMB
    Yea it has a set of Jahns (sp?) pistons the heads have had a lot of work. Aluminum flywheel. All the typical stuff. Stock bore 401.
    I had the fuel pump apart. it was locked up from all of the fuel. Ill have to send it back to hilborn and get it flowed and repaired along with the injection.
    The Vertex is in the original box and I have the Isky cam tag and a tube full of "pills". Its actually crazy that all of this stuff stayed together for 40 years. It was all in 4 huge cardboard boxes.
  2. 454navyss
    454navyss
    awesome restoration, we need some new pictures of your progress
  3. porkshop
    porkshop
    from Clovis Ca
    Thanks for the update.....John
  4. Sebastian.A.G
    Sebastian.A.G
    from argentina
    waaaaho man nice pickup drag.
    the rear end fixed to the ch***is better or worse traction in the drag race?
    regards
  5. Hot Rod Michelle
    Hot Rod Michelle
    Cool truck. I think that one of the Rat Rod Skool Magazines did a feature on this truck, some time back.
  6. AHotRod
    AHotRod
    Are you still working on it ?
  7. GaryB
    GaryB
    from Reno,nv
    how's that truck com'in?..pics
  8. abone1930
    abone1930
    Subscribed :D Awesome truck.
  9. VA HAMB
    VA HAMB
    Its coming slow....(two young kids that play ball :)) I have the frame painted and the front suspension ready to ***emble. As soon as I get it rolling I will post some more pics. Thanks to all for keeping me moving.
  10. VA HAMB
    VA HAMB
    OK here are a couple updated pics. Like I said its coming very Slloooww... I have trouble finding time to get anything done. I now have the spindles on and am finishing up getting the rest of the front suspension linked up then a final coat of paint. Hopefully I will have this thing back on its wheels soon.
    [​IMG][/url][/IMG]
    catdad49 and volvobrynk like this.
  11. lawman
    lawman
    Very nice work. Keep posting .Tom (Tired Old Man)
  12. ynottayblock
    ynottayblock
    I absolutely love this truck, Im so glad to see you give it the proper restoration it deserves. Cant wait to see more progress.
    volvobrynk likes this.
  13. VA HAMB
    VA HAMB
    Thanks guys!
    2510 fab and Ron Funkhouser like this.
  14. VA HAMB
    VA HAMB
    Here are a couple of pics together that i thought were pretty cool. 1964 and 2009
  15. VA HAMB
    VA HAMB
    Not much going on this winter. I just dont have good enough heat to get things going. I did manage to get the front suspension back together and the wheels down and I also went back through the frame rails and touched up some "pits". So now once it gets warm and after the rear is back together, I will re-sand and paint again and then start on the body.
  16. VA HAMB
    VA HAMB
    Not too much to report. I was able to finally find the parts I needed to get the rear back together. (wasn't exactly sure what it was) I ve done a lot of small things that you can't see. I had to roll it out so I can start to put a new engine in my Sedan so I'll have something to drive to the Jalopy Showdoan in May. After that I'll get back on the truck. The cab will be next.
  17. neverdun
    neverdun
    Keep up the good work. Nice job so far!
  18. Eightydeuce
    Eightydeuce
    Any updates?
    Here's a picture I got from an older friend of mine who's in his 70's, he took this picture at mason dixon dragway sometime around 1964.
  19. VA HAMB
    VA HAMB
    AWESOME!!!!!!!! Thanks for sharing.
    Ron Funkhouser likes this.
  20. Love that thing! Looking forward to seeing it back in one piece.
  21. John 79
    John 79
    from Sweden
    Great car,just love it!
  22. 47kb1
    47kb1
    from TN
  23. AHotRod
    AHotRod
    Did you finish the restoration?
  24. VA HAMB
    VA HAMB
    Hell, I wish! I had to put it aside for a while to get my "show going" rod back on the road. Just about done then I will start back on the body this winter. Family and money holds me back quite a bit but I am keeping at it the best I can. Stay tuned!
  25. VA HAMB
    VA HAMB
    Just in case anyone is still interested, I'm still working on the truck. Actually I've been hitting it pretty hard for the last few months. I have the engine ready to ***emble, I'm just waiting on some bearings to show up. Apparently Standard Main bearings are hard to come by. Luckily the truck came with an extra block, and crank (the original was broken due to a blown clutch on its final run 50 years ago) I was able to hone it and hopefully it will hold up for a few p***es. all the other parts, Lifters, cam were still in the original block but they cleaned up real nice. I have also rebuilt the fuel pump and Hilborn Injection but I'm sure Ill eventually have to send it back to have it flowed. Not sure yet.
    The fuel cell was full of used motor oil but there is a smaller tank inside that held the secret Alcohol! so Ill have to cut the end off of the tank and remove that and see if the main tank is clean enough to use. If not, Ill fab a replica. As soon as I get the engine in Ill start on the cab. I have most of the patch panels I need so hopefully it wont take too long to finish it, but baseball season is getting close and that will eat up my time. I would post photos but with new HAMB I cant figure out how. It ****s IMO. Later!
  26. VA HAMB
    VA HAMB
  27. Martin_F
    Martin_F
    Yes, we're still interested!
    Good to hear from you Todd, and that you are still working on it.
    I still have to get up there some time to check it out in person...
  28. VA HAMB
    VA HAMB
    Come on Martin!
  29. gnichols
    gnichols
    from Tampa, FL
    Welcome back and yes, please post more and more and more! Gary
  30. bowie
    bowie
    Love your truck,nice progress. Keep up the good work!
