Straight axle idea/question
Discussion in 'The Hokey Ass Message Board' started by Gearhead Graphics, Jun 17, 2010.
  1. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Been heavily thinking about building a truckster from a late 60's or early70's ford pickup. I really want it with a straight axle and transverse leaf front. On some older fords they have a straight with parallel leafs. Anyone ever made one of these axles work with a transverse? If so how? Or are there any good arguements why not to.
    Just trying to plan this thing out as much as possible to use as much of the donor truck to keep costs low as possible.
    Thanks for any input or ideas.
  2. 62rebel
    62rebel
    my first thought would be the mixing of suspension geometry... personally, i don't think it'd drive well with the mixed types.
    given THAT; i've been playing with the concept of doing a rig out of a late fifties to mid sixties pickup with parallel at each end, setting the engine and trans back and relocating the steering box back further, then building a speedster type body on the frame. no longer a "truck" at all... but then i'm nuts anyway.
    it'd be a sort of 3/4 scale Blastolene Special....
  3. Anderhart Speed
    Anderhart Speed
    I think it would be ok, the thing is you would just have to make your own spring mounts. Most of our stuff uses a specific axle (mostly superbell, original stuff, or possibly a magnum, all pretty similar), and most of the suspension parts are designed to mount/work with that specific axle. Its hot rodding, you can do whatever, just make sure you do it right.
    Another option is Posies quarter elliptic springs (I think its called ellipti-slide or something like that) check out george poteets new pickup-they used them on the front and the rear, very cool. They are pretty cheap to I think.
  4. canman
    canman
    Flemke Front End. Most of the '60 and '70 Circle Track Mods had 'em circlehttp://www.jalopyjournal.com/forum/showthread.php?t=46449
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Ahh yes, quarter eliptical could be way cool too. Biggest variable there would be my frame width. Of course I can make it any size I want, just looks and proportions...
    Good ideas...
    The rear WILL have a transverse or quarter eliptical along with the super short bobbed off box. Thinking of shortening the stuffing out of the stock box even for this. Mostly depends on the condition of the donor truck I end up with.
  6. 62rebel
    62rebel
    ah; i didn't get that you were redoing the design. i guess my thinking runs along symmetry, really; what's up front is like what's out back.
    i been daydreaming about Allards a lot, too....
    but i'm leaning towards a beat F-1 to use as a base.
  7. designs that work
    designs that work
    The west coast Super Modifieds of the 1970's used 1956 Ford pick up front axels that were narrowed and used the pre 1948 Ford cross springs. Simply made spring perch, round tubing with a 5/8 inch bolt welded to it. Flat plate welded to axel.
  8. swade41
    swade41
    from Buffalo,NY
    If you found a big enough piece of angle iron at least 3/8's thick that would cover the four mounting holes for the orginal spring u-bolts. You could bolt that down through the four holes with the vertical side facing in on both sides. Then just drill a hole in the vertical side to accept the suicide style spring perch that would normaly bolt into a bat wing.
    Of couse you would have to tie into the same angle iron to run your radius rods too.
  9. gimpyshotrods
    gimpyshotrods
    AD Chevy I-beam, cross spring, simple mounts that put a eyelet above where the springs were.
    Not mine, but spotted at Billetproof Nor-Cal '08 and '09.[​IMG]
  10. Here's a setup I did for an O/T rod project.
    Are you going to build the frame from scratch, or try to use the truck frame as a starting point? Also, I think you're going to have to way back into the early 60s to find a solid axle Ford. Didn't they go to twin I beam in about 65-66?
  11. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Starting from scratch. I figure that will be easier than polishing a turd. I mean making the factory one look clean and nice like I'd want it to. Kinda kicked around the idea of getting a prefabbed or at least kit t bucket frame and modding that.
    Yes swapped to twin I in 5or6. Looking at some mid 60 donor trucks and up to 70.
  12. 1965.
  13. another possible source for 1/4 elliptic springs are Ford Aero Star vans
  14. marioD
    marioD
    are you saying Ford Aerostar vans have 1/4 elliptic springs?
    Mario
  15. Ummm... I think cutting the ones off the donor axle in half makes them work, too. No need to over-complicate things.:eek:
