Using 40 Ford X member in a Model A Frame
Discussion in 'The Hokey Ass Message Board' started by aldixie, Jun 17, 2010.
  1. aldixie
    aldixie
    Hi Guy's,
    While searching AV8 builds a couple of weeks ago I found someone using a 40 Ford X member in a model A frame. Used the search function again but can't find it help!! He had narrowed the height of the X member to fit.
    I want to ask the owner a few questions.
    Thanks,
    Alex
  2. EricVA
    EricVA
    That's what I did to my A Frame. Think I did it wrong though because the back end of the X sits too high and the rear of the engine is not level with the front. I need to go back rethink it. I took a pie cut out of the top side of the rear section of the X when I think I should have pie cut the bottom. I was looking to keep the X from hanging down low. It has kind of a "sag" in he middle. The front of the X I pie cut the top side, it's not real pretty right now but it should work when it's all sorted out.
  3. aldixie
    aldixie
    Thanks for the pictures. It gives me some ideas. I have a F1 crossmember but was thinking about going to the 40 Ford crossmember.
  4. Kevin Lee
    Kevin Lee
    Super Moderator
    Here's how I did mine:
    Cross member tech for the AV8 guys
    The transmission mount was a little too high and as a result my engine was dead level which always bothered me a bit. So I would do that differently if I built it again. Instead of mounting the transmission to the top of the X I would rework the stock mount and put the transmission mounting ears right below the top of the X then holesaw it right above the engine mount nut for access.
  5. 8-Track
    8-Track
    I think B*** used one for his frame
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    B***' was a '32 but yes, he has done it a few times I think.
    I was given an old book with some tech for this after I did mine. I was just using what I could get my hands on at the time and honestly it was pretty poorly planned. I just happened to get very lucky with my placement of things.
  7. BISHOP
    BISHOP
    There is an add in Rod&Custom for X members made for a model A frame, they look good.
  8. treb11
    treb11
    Dagel's
  9. Flat Ernie
    Flat Ernie
    Tech Editor
  10. aldixie
    aldixie
    I just picked up a 40 Ford X member from another Hamb member for $60. I'm going to mock it up and see how it will fit.
  11. Hitchhiker
    Hitchhiker
    damnit, I wish I could find a x-member local for 60 bucks!
