54 belair tire info need help thanks
Discussion in 'The Hokey Ass Message Board' started by JACK30, Jun 21, 2010.
  1. JACK30
    JACK30
    from PA.
    hi im putting new tires on my 54 belair its lowered 3" do the 205/75/15 on a 54 hit the front fender or frame when you turn hard and is their a problems removing the back tires with out deflating them with 3" lowering blocks, hate to go radial but im tired of side walls flopping arround corners thanks jack
      131 KB
  2. tomc
    tomc
    My 215's did not hit up front,had to use 2 jacks to change back tire. The rocker was about 4" off the ground up front.
  3. catbox
    catbox
    my 54 runs 205/60/15's and hydraulics.
    that said it hasn't presented be any problems at full drop
    i know they are not the 75 series you are looking for but i thought i would throw it out there for you....
