  1. ChopperOlli
    ChopperOlli
    from Finland
    Heres fast shop for '54caddy:
    -Olli
  2. '54Caddy
    '54Caddy
    wow, Thanks Olli!
  3. original patina
    original patina
    from Texas
    xhotrodder, do you have a larger version? Low resolution is more difficult to Photoshop.
  4. bobj49f2
    bobj49f2
  5. UnsettledParadox
    UnsettledParadox
    a .gif, how bad***!!!
  6. SDhotrod
    SDhotrod
    Sure, no problem.
  7. xhotrodder
    xhotrodder
    Thanks bobj49f2, I pulled my request because I figured the picture was too small. You nailed it the way it was, thanks. xhotrodder
  8. PhatCaddy
    PhatCaddy
    Ok, I'm loosing the side pipes next week and filling in the side covers.
    #1 idea is 2-tone, black w/gold flake or some pattern top w/ white int
    #2 idea is all Artic White/white int (sort of how it is now)
    #3 idea is the last green
    Any ideas??????
    Have fun......
    Brian
  9. SDhotrod
    SDhotrod
    Here are a couple of other options:
    And finally, what you requested. [​IMG] For the love of Pete, don't do it!!!;)[​IMG]
  10. KQQ16
    KQQ16
    Thanks for that. Don't wanna push the friendship but any chance of a bit thinner?
  11. SDhotrod
    SDhotrod
    Hi,xhotrodder,
    Someone should have clarified that to make it easier to work on the pic should be at least 640 x 480 pixels with descent resolution and clarity. 800 x 600 is ever better. The pic you just posted is 469 x 285 pixels in size(the same as you previously posted) and is quite fuzzy and low res. Small pictures can be Photoshopped if they are higher in resolution. Hopefully you can get a bigger picture of your car and we can help you out. Don't be afraid to ask questions if you need some help in getting a better pic of your car uploaded.:)
  12. speedwise
    speedwise
    You Photoshop guys are awesome. One of you put different mags on my truck and it looked *****in. I'm now thinking of scallops maybe two maybe three on the side coming from the front of the cowl past the door. I'll let you guys decide if they are the same length or one shorter than the other. As far as color goes, white, red, no pink... You all have the artistic eye. I would also like to see some chrome reverse with the wide whites. Hope I'm not asking too much. Keep up the great work. We love it.
  13. xhotrodder
    xhotrodder
    Thanks, I'll see what I can do. Slightly computer illiterate.
  14. 56pu
    56pu
    from Sarver,PA
    Can some one play with my old dodge, Im thinking about Smoothies, or what ever would look good
    Thanks
    Harmon
  15. sinks88
    sinks88
    just checkin in, seein if I got something back
  16. James D
    James D
  17. Last edited: Jun 24, 2010
  18. concreteman
    concreteman
    :D looks Great
  19. nwaringa
    nwaringa
    This guy could use some dark red rims, dark blue paint, and some red scallops. I'd be mighty grateful.
  20. PhatCaddy
    PhatCaddy
    Thanks James.........
    Any other ideas?
    B
  21. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    Are you stuck on green? I don't like it on your car ;) :D
    How about a dark purple or something else that is dark and sinister?
  22. James D
    James D
    Not white!
  23. James D
    James D
  24. Rikster
    Rikster
    Great work JamesD...
    Made me wonder how it would look in two tone with black on top and the color separation below the belt-line to lower the car even more optical. I also gave the car a bit better stance :) All the hard work done by JamesD... made this one easy to do now.
  25. James D
    James D
    Couple more choices for you...
  26. sinks88
    sinks88
    dude! I have not seen a plymouth lookin that good! can you make the rims black? and add a visor?
    Was that chopped about 2 inches?
    How about frenched headlights?
  27. James D
    James D
    Yes it´s chopped about the thickness of the door window frame. I think the chrome wheels look better than black. You can overdo the black thing IMHO, it needs something to liven it up a bit. Sorry, but I hate visors!
  28. sinks88
    sinks88
    No, I agree about the Chromies!!!
    So do you have an idea about the grill?
    I love the look right now....this really gets me going.
  29. PhatCaddy
    PhatCaddy
    Hi Megan, not stuck on green but I just wanted to see how it looks. I agree with a dark color like black 2-tone (black bottom). With it in the gray primer now I relized the light color won't shock the car.
    Thx Rik and James,
    Brian
  30. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    I'm thinking like Jeff Myers Caddy dark plum-purple or something along those lines. Something to make it look gangsta'! :D
