old Buick marine engine / what is this ??
Discussion in 'The Hokey Ass Message Board' started by Mark, Jun 26, 2010.
  1. Mark
    Mark
    from CT
    sorry fellas, but we are a Ford family over here . Ran across this, is it anything good ?? all i know its a Buick marine engine. what year / what size could it be? should i get some numbers off it ? It does have a manual trans flywheel like brand new, with the marine adapter plate Thanks!
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Buick 350 marine engine?
  3. cj92345
    cj92345
    from so-cal
  4. repoguy
    repoguy
    yep. looks like 300.
  5. Babyearl
    Babyearl
  6. It's NOT a Nailhead...................................too bad.
  7. franklgr
    franklgr
    from SWPDX
    If the block is aluminum it is a 215 which they also used in some inboard/outdrive units. Johnson used it in a boat they built for a short time.
  8. Mark
    Mark
    from CT
    thanks fellas, they were asking 250 for it, if it was something cool, i wouild have picked it up.
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    My dad had one in his 66 chriscraft .....
  10. Jonnie King
    Jonnie King
    from St. Louis
    You're right to "bail out" on this one. Much more trouble than it would be worth.
    On the otherside of that coin, if it was a Buick straight 8 ohv they are very cool, run smooth as silk, and are pretty bullet-proof. AND, here's the reason I mention this:
    Many straight 8's found a new life after the bodies were trashed. They were used as "industrial engines" in sawmills, factories, etc., a lot of them found homes in the lumber harvesting areas of the country. These were usually 263's or 324's.
    SO, if you're looking for a solid, unusual piece of rodding material...with gobs of torque, the straight 8 could be your weapon of choice. And, unlike the Marine engine you were looking at...these usually never got wet !
    JK
