  1. SDhotrod
    SDhotrod
    The stock grill is starting to look pretty dang good to me too! ;)
  2. James D
    James D
    X3 - I messed about with a few of these now and there isn´t much that seems to look better than the stock grille. Not without major work at least.
  3. James D
    James D
    Went with maroon with white and a fade in the middle.
  4. xhotrodder
    xhotrodder
    Dude, Not trying to tell you what to do with your car, but you should make the interior last. That way there is no chance of overspray, getting on your brand new interior.
  5. zgears
    zgears
    Can anyone tell me how to lower and chop using Gimp? or direct me to a good tutorial.
  6. RocketPinstriping
    RocketPinstriping
    from Waco Tx
    maybe someone could give me some ideas on what to do with my old Merc? i would like to keep it white, maybe a cool flake color for the top? or a panel scheme with the white as the base? reason being i dont want to go full color change... wide whites, lowered a couple... but im open... im not so good with gimp. thanks
  7. original patina
    original patina
    from Texas
    Quickie. Not a fan of whitewalls on a white car.
  8. zgears
    zgears
    Ok... I'm going to answer my own question. If any one wants to try this, down load Google Gimp(free) and fool around with "clone tool". thats all I used for this.
  9. flynstone
    flynstone
    wow thats cool, but not knocking my socks off............i am going to get rid of the chrome down the middle.......thanks................mr x, ya..... i hear ya but the window to get the interior done was now..........................hmmmm the more i look at it,, kinda growing on me,,,,,,,,,,,any other options thanks again
  10. zgears
    zgears
    Crude but Im leaning..
  11. OahuEli
    OahuEli
    from Hawaii
    If you ever want to go the G***er route, this might work for you.
  12. SDhotrod
    SDhotrod
    Here's a quick tutorial on lowering with GIMP. It's my first tutorial so go easy on me and don't be afraid to ask for clarification on any on the steps. I don't know your level of experience with GIMP, so forgive me if it sounds like I'm talking down to you. Also, there may be a dozen other ways to lower a car in GIMP/Photoshop, but this is the best way I know of to do it. I'd be interested to know how you other guys do this.
    I use the Paths tool to lower a car. I'd learn how to use the path tool well, as you can use it to do many things while Photoshopping, or should I say "GIMPing" a car.(Also notice the Move tool as you'll be using that later on)
    If you need to learn how to use the Paths tool do a Google search for "GIMP Paths tool tutorial".
    Now use the Paths tool to outline(select) the base of the car and then up the sides of the pic and over the top. You can see in the pics below where I've ran the path:
    Next, in the "Select" drop down menu at the top of the GIMP window, choose "From Path". What this does is use the path you've created to make a selection of the original picture.
    Now, go to the Select drop down menu again and choose "Float". As it says, this will float/ separate the selected area off of the original picture.
    Next, chose the move tool in the tool bar and use it to drag the floating section down. lowering the car.
    You can also rotate the floating section to get the car level or to make it an *** dragger. You can also use the directional keys on your keyboard, instead of the mouse, to lower the car after you've selected the Move tool and left clicked inside the floating selection.
    Next, in the layers dialog right click on the Floating Selection layer:
    And select "Anchor Layer":
    Then just crop the pic to get rid of the blank space at the top of the pic that was created when you lowered the car. I hope this helps!(and I hope it make sense as I'm 3/4ers brain dead as I write this...
  13. flynstone
    flynstone
    bingo,,,,g***er .......
  14. bonez
    bonez
    from Slow lane
    Breeze window Merc!
    Thats what they called right?
    Theres a really neat one from japan, Ace Kustoms, check that out.
    Go late 60s early 70s w/ it and you win. Nice car.
    Oh, also someone on here has a nice one, Bigdaddyo i think is the name. NO www, this cars deserve pinners, either single doubletriple, gold or white. But no wides.
  15. RocketPinstriping
    RocketPinstriping
    from Waco Tx
    Bonez
    im kinda new to the traditional worl, so forgive me:confused: what are pinners and doubletriple? ive probably seen but never knew the name...:p
    ill have to check out the mercs you mentioned, thanks!
    Thanks! i like, but when i do it i may use a darker roof... i didnt think about the white walls on white thing:rolleyes:...
    you got me wanting to shave the excess chrome pieces now:mad::D maybe a later mod, but after seeing, i am severely tempted.
  16. zgears
    zgears
    Nice work, and thanks for the tutorial.
  17. SDhotrod
    SDhotrod
    Pinner whites are just thin white walls. I think the word is a mix of thin and pin stripe.??? I have no idea what doubletriples are.:confused: Two or three thin whites walls??? I need some schoolin' too.
    Astro Supreme wheels and I lowered it a bit.
  18. OahuEli
    OahuEli
    from Hawaii
  19. OahuEli
    OahuEli
    from Hawaii
    [​IMG][​IMG]
    Z,
    Here's your car with the body sectioned about 6 inches, the top chopped about 3 inches and skirts. I tried to do the Copper you requested but it kept coming out looking like a puke orange.:eek: Maybe someone with the color skills, like James D, Skoh, SD or someone can run with this. The lines of this car are great, there's all sorts of possibilities. Good luck with the build.
    Eli
  20. RocketPinstriping
    RocketPinstriping
    from Waco Tx
    WICKED! a friend of mine said i should put astros on it ill have to search for a set asap!
    i gotcha, now i have increased my rodder/kustom vocabulary
    and, i will stay away from doubletripples... esp if it involves tequila
  21. 57tony31
    57tony31
    from Woods
    Could someone help with this pic maybe flat blue and a sliver flake top.Or whatever you like:D ty.
  22. James D
    James D
    Real quick one for you.
  23. 57tony31
    57tony31
    from Woods
    Thanks man guess thats out hah.
  24. bonez
    bonez
    from Slow lane
    Yeah this is what im talkin about.
    Triple pinners have 3 thin white stripes, double have 2, dunno if this is the correct name but i suppose it is.
    Anyway, here is an example of a triple thin white, but i must admit maybe it wouldnt look as good on your car. Im thinkin either a 3/4" or 1" white would swit best.
    Also a pic of the Japanese Breeze away.
  25. James D
    James D
    God I hope so!:D
    What sort of thing are you going for? Racer, Kustom? Are the five spokes staying? Chrome on the sides?
  26. duckman rob
    duckman rob
    from NW Indiana
    Hi could someone help with my truck? If you could do flat black on bottom and flat silver on top two tone with the two tone broke up at the belt line on the cab.
    thanks in advance, Rob
  27. Julio
    Julio
    from san diego
    hey I hope someone can help me with photoshoping my comet, it was done a little before but I wanna see how this would look (the green) but with a black flake top (I was thinking black with gold flake) or even just 2 tone the green on bottom with the black on the whole top side, or in the space between the sede chrome, I guess its just on the shoping board and let me know what you guys think!
    please and Thanks a bunch in advance!
    -Julio
  28. jibby
    jibby
    Just wanting to see this shopped. Go crazy with it!
  29. We bought this under restoration 28 chevy to build an old school banger. Picture this, Fenderless, channeled 10 over the stock ch***is with the original wheel and tire combo maybe a little flat green paint and open top. Anyone willing to photo shop it to those specs?? thanks!!
  30. HotRodNisse
    HotRodNisse
    :cool:
      346.4 KB
