I SCREWED UP, the june thread did not show up in the hot rod index so I started another one. HERE IS THE LINK BELOW TO USE. Sorry for the confusion but I wanted people to be able to find it.. T- Head http://www.jalopyjournal.com/forum/showthread.php?t=480060
Here is the banger link list . For the HAMB banger newbies, here are some links to a lot of banger info: Flat Ernie maintains the monthly link list. Every month is listed: http://www.jalopyjournal.com/forum/s...d.php?t=161498 Banger basics. another info link list: http://www.jalopyjournal.com/forum/s...d.php?t=251717 http://www.jalopyjournal.com/forum/s...ad.php?t=42480 Post #105 of link below shows flywheel lightening dimensions http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6 Elrod's stuck head tech: http://www.jalopyjournal.com/forum/showthread.php?t=218487 Gear ratio / speed and RPM calculator: http://www.accuautoparts.com/calculatorfin.jsp Model A master cylinder mounting bracket ideas: http://www.jalopyjournal.com/forum/s...73#post4953173 Chevy Banger Stuff http://www.jalopyjournal.com/forum/s...d.php?t=463465 Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine" http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931 Post 198 starts a great discussion of the shape of a flat head combustion chamber http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10 Maybe these links should be posted early in each months meeting. If anyone knows of more, please post them.
is that a coupe made into a roadster? or a pinstripe making it look that way? edit.... looks like a pinstripe... I sure like those 30-31's with the 32 grill and all the fenders....
Great stuff guys, I love the monthly banger meet. Got my engine painted, just waiting on my Snyder head so I can start driving again.
I SCREWED UP, the june thread did not show up in the hot rod index so I started another one. HERE IS THE LINK BELOW. Sorry for the confusion but I wanted people to be able to find it.. T- Head http://www.jalopyjournal.com/forum/s...d.php?t=480060 __________________ www.roadinosaur.com
Got a couple questions, what kind of comfortable top speed can be had with a 39 three speed behind a mostly stock banger, I ask this because I would like to get the three speed/overdrive newer ford trans conversion but I already have a 39 trans and can do that conversion for 350 bucks versus over 2000 for the other... and the second question is will an engine run fine with a 7:1 head on babbit? Everybody says it won't but I have a bar of babbit that has a little more nickel in it than normal so wouldn't that make it a little harder and be able to handle the little extra preasure? And I don't drive like a maniac mind you, I give her a go every now and again but I just want to be able to drive her pretty much anywhere I wanna go.
