348 i.d.?
Discussion in 'The Hokey Ass Message Board' started by Maco-B, Jun 28, 2010.
  1. Maco-B
    Maco-B
    Found a 348 Chevy block and heads. The casting # on the block is 3755011 . Which comes back as a 58-60 348 "Wedge". But my old Hollanders only go back to 62. So I can't identify the serial #. It's stamped T0 60 9F . The date code is F1 60 and the heads casting # is 3758379. Any help? Thanks!
  2. go to 348-409.com they got everything
  3. Heads and block show up as 59-61 p***enger car 348 in my book. Doesn't show anything special.
  4. Maco-B
    Maco-B
    Thanks, I tryed that. i just want to find out if was a car/truck engine?
  5. Maco-B
    Maco-B
  6. Like I said....p***enger car.
  7. Maco-B
    Maco-B
    Thank's for that. Anyway I could find out what body of car from those numbers?
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No. It didn't matter if it came in a Biscayne, BelAir, or Impala; same I.D. code.
  9. lowelife
    lowelife
    the casting numbers don't break it down that far.
  10. Maco-B
    Maco-B
    Well Thank's for the info. I also posted the serial # that's stamped in the block on the right hand just before the cylinder head. It is T0609F its not a casting #.
  11. Tony
    Tony
    T= Tonawanda engine plant
    06= June
    09= 9th day
    F= suffix code- 58-61 p*** car 250hp 4Bbl carb manual trans
    The date code will tell you what year it is exactly. Which in your case would be June 1st, 1960.
    Your block was cast on the 1st, and machined on the 9th for a 1960 car.
  12. Maco-B
    Maco-B
    Thanks Tony. I'm not quite sure what to with it yet.
  13. Tony
    Tony
    You're welcome. That would make a great powerplant for just about anything.
    But i am biased.....'W' motors are my favorite bent 8 :)
    Tony
