alternative accessory idea's
Discussion in 'The Hokey Ass Message Board' started by theglassman, Jun 29, 2010.
  1. theglassman
    theglassman
    me and a friend of mine are brain storming about runnin his altornator
    in a remote location away from his motor.......due to space....
    we've read all there is about the rearend mounted ones...
    seen some different ideas out of the compo***ion stereo world....
    my idea is to use a small electric motor with a v-belt simular to what is used for a water pump.......
    i understand the motor would be hooked to the battery and such....
    the only real load on the battery is an HEI, and a automatically controll cooling fan with the ocasional head light or two....
    anyone see anything im missing here ....or have any ideas....other than the drive line mounted one.........
    weve also seen the cable driven one to........
  2. Jimmy2car
    Jimmy2car
    from No. Cal
    I'm not sure that I understand. You want to run an alternator with an electric motor? In a remote location? It (alternator) needs to be driven from some portion of the running gear in the car. I've seen them on the engine itself (normal fashion), driven from the transmission slip yoke, and driven from the rear axle yoke. I don't think you can make a perpetual motion deal out of this, but if you do, let me know first.
    Jim
  3. binderfan
    binderfan
    from bay area
    I was just thinking the same thing...perpetual motion machine?
    How are you running the electric motor, from the battery? Why not cut out the middle man and run the whole car off the battery then? Seems like you'd have the same set up either way: a dead battery in a few hours.
    Maybe I just don't understand....
  4. theglassman
    theglassman
    why couldnt you run the alt "motor" with the battery and then run the rest of the car off of the alt..............
    with the alt mounted off the rear end it wont be charging while the car is stopped.....im tryin to fix that problem.........
  5. BISHOP
    BISHOP
    Put a big fan on top of the car....... connect the fan to the alternator, problem solved.
    Turbo driven alternator hasent been invented yet, jump on that.
  6. Heo
    Heo
  7. DD COOPMAN
    DD COOPMAN
    You's two guys could probably get jobs as scientists for the guvmint. DD[​IMG]
  8. adamshumard
    adamshumard
    ..............WOW................... i thought i had bad ideas.....
  9. BISHOP
    BISHOP
    Cable driven alternator???? Where did you see that???
  10. You'll be better off to find some way to mount the alternator on the engine and pull it with a conventional V belt or serpentine belt setup. If you're not pulling a lot of accessories and don't really need a high amperage alternator, there are some very compact size alternators available. I talked to a guy with a T bucket that had a very bare bones electrical system--I noticed the very small alternator and asked him about it. He told me that it was a Kubota tractor alternator and said it worked fine.
  11. pasanger seat get a set of pedals and have that person redal
  12. adamshumard
    adamshumard
    I say mount a fifth wheel out back with a spinner on it. and a pulley on the spinner with a belt ran off of it to the alt. that way when you stop it keeps charging. I may patent the idea as the "kine***ron" so hurry with yours.
  13. Russco
    Russco
    from Central IL
    This reminds me of the DIRECT EXHAUST INJECTION idea
  14. dodgord
    dodgord
    why use a battery at all? use the power from the alt to run the electric motor!
  15. gimpyshotrods
    gimpyshotrods
    Entropy, as in the Second Law of Thermodynamics.
  16. Some commercial p***enger jet aircraft have a drop -into -the airflow prop driven hydraulic pump. (Airbus I think ).If that does'nt work they make you wind the widows down and flap your arms.
  17. KrisKustomPaint
    KrisKustomPaint
    just wrap rubber bands around the pulley and wind it up.
  18. Bloodandmotoroil
    Bloodandmotoroil
    shaft drive it to a turbo on the exaust, that way you can have it anywhere and i've done it, works well , used it with gens to. and a/c pumps and power stearing pumps, its good for space saving showcars.
  19. Domino
    Domino
    One of the coolest alternator drive systems I have ever seen was one we came up with several years back. A friend of mine was looking for a way to get the alternator out of the way of a motor plate and eliminate the alignment problem. I suggested running the alternator directly off the crank pulley. We came up with the idea of engaging the alternator pulley with the harmonic balancer. We made a 4 pronged cup that bolted to the center of the harmonic balancer and we made another one to bolt on the alternator. We bolted the alternator solidly to the engine with a bracket and lined up the couplers. The crank drove the alternator directly. It worked fine, but our design was very crude. It could be refined to look and work perfectly. His car had an electric water pump, so the belt was eliminated.
  20. JoeySwass
    JoeySwass
  21. gemcityrenegade
    gemcityrenegade
