What's your favorite penetrating oil? Look @ this
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jun 30, 2010.
  1. historynw
    historynw
    nitroglycerin....to make it go kablewiee that will unstick it.:rolleyes:
  2. fab32
    fab32
    Gibbs............hands down.
    Frank
  3. srdart67
    srdart67
    from Sharon, Wi
  4. seventhirteen
    seventhirteen
    from dago, ca
  5. mace69
    mace69
    from mass
    Dynamite, if that doesn't work try some GM top engine cleaner. that stuff eats everything.
  6. GMC BUBBA
    GMC BUBBA
    another vote for Kroil, and it does take time............
  7. DanCollins
    DanCollins
    never tried Kroil, but I'm for sure a Gibbs guy, and I can brig you down a can on friday if you want,I have that distributor I want you to look at....I stock Gibbs at the shop, and it works great for other stuff too...
  8. bigguylilroof
    bigguylilroof
    ditto!!
  9. Bring them both, and we'll go from there. Thanks
  10. carlos
    carlos
    from ohio
    Kroil once you use it you will throw the others out
  11. gimpyshotrods
    gimpyshotrods
    That was not Kool-Aid. It was Flavor-Aid.
  12. GARY?
    GARY?
    I really like the Kroil too. Used it for years back on the East coast where stuff gets stuck as #$@!.
    It really irritates my hands though, can't go near it without gloves on.
  13. zibo
    zibo
    from dago ca
    straight brake fluid.
    TP
  14. Kevin Lee
    Kevin Lee
    Super Moderator
    I was recently reading somewhere that some independent tests were done and the acetone/ATF mix worked better than anything you could buy outright.
    Have also heard a couple of odd ones:
    A certain penetrating dye used to test for cracks is supposed to be great because it is oil based and WILL find every little imperfection. Seem to remember it being cost prohibitive.
    I have a friend who tried for months (if I remember correctly) to separate a pretty rare aluminum and steel hub/drum/brake combination. After several rounds of various penetrants he washed it all off and left the whole mess submerged in WATER. Do not remember exactly how long it took but it wasn't long and they came apart easily.
  15. Ebbsspeed
    Ebbsspeed
    Why not just take the valve out and clean the stem and guide? Then you won't have to worry about all of the debris that is causing it to stick now making it stick again once you get it running. All of the penetrating stuff will make it come loose, but whatever is causing it to stick is going to still be there causing undue wear and the possibility of it sticking again when you really don't want it to. Fix it right, fix it once.
    What's the motor, flathead Cadillac/Lasalle?
  16. gotit
    gotit
    sea foam. I love that stuff
  17. brucer
    brucer
    from western ky
    liquid wrench
    pb blaster
    seafoam
  18. jonathan
    jonathan
    from Phoenix,AZ
    I've heard of the use of water as well, like on hinges and stuff. Then follow up with WD40 or similar. Makes sense, because thats what got in there in the first place!
  19. twoANDfour
    twoANDfour
    Dunno if anyone has mentioned it yet, but there's a product called Aero-Kroil.
    Big orange can. Smells awful. But works wonders.
    Give it a shot if you can find it locally.
  20. cafekid
    cafekid
    At work we use a penetrant called Twister. i belive its made by Selig Industries.... the stuff kicks *** and doesnt smell like ****
  21. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Gibb's Gibb's Gibb's..............................I put that **** on everything.
  22. Baumi
    Baumi
    I always use Ballistol on stuck pistons and valves, it always helps to break up rust and grime. I don´t know if it´s availible in the US but that´s the best thing I´ve used.
    Chris
  23. harrydude
    harrydude
    from ab
  24. Okie Pete
    Okie Pete
    Seal off the holes with rags . Then fill up port with acetylene . Take a old electric cord cut off the female end . Strip two wires bare and twist the bare ends together put the twisted ends in the port before the acetylene and rags. After filling with acetylene step out side plug in cord.:rolleyes: Maybe not a good idea .After the dust clears and your ears stop ringing you may need to rebuild more than the head . OK bad idea I vote for Kroils
  25. Bloodandmotoroil
    Bloodandmotoroil
    home brew **x. just take every lube and oil and hydralic fluid in your shop or gurage and mix it togeather and pour it it.. then wait for 3 days and then do what you do and presto ya got it unstuck
  26. davis574ord
    davis574ord
    K- y jelly! Works for all kinds of stuff!
  27. because...it's STUCK!
  28. wingman9
    wingman9
    from left coast
    Definitely Kroil. And you can buy it all day long from Eastwood.
  29. Rattaxi48
    Rattaxi48
    from ohio
    strong arm **** works great cleans off surface rust like a metal polish havent had to heat anything up since i found this **** i havent come across anthing that i havent been able to get loose and i live in ohio our **** will rust before your eyes check out their site http://strongarmsprays.com/
  30. Francisco Plumbero
    Francisco Plumbero
    from il.
    Put it in the freezer for a day, the valve stem will shrink, thats how they do the rocker studs on 302 fords.
