how much is too much? shoebox chop
Discussion in 'The Hokey Ass Message Board' started by 51fordshoebox, Jun 30, 2010.
  1. 51fordshoebox
    51fordshoebox
    well i found a donor with a good stock roof, so i may just go for it, and redo the top..
  2. hmm
    carson top remade to the height desired ..then go roofless somtimes
    ifn its the chop that you are paying for .....ask for the leftovers
  3. Strange Agent
    Strange Agent
    I wouldn't go that much, but it's not terrible. It looks like it dips too fast after the door pillar.
  4. fleetside66
    fleetside66
    I noticed the same thing right out of the chute.
  5. bigskybob
    bigskybob
    First off, this is a radical chop. That being said, if you look at the front 1/4 view picture, the windsheild looks good and the BUBBLE AREA above the windsheild is fine, BUT at the top front edge of the bondo strip to the back looses all of that BUBBLE shape. It makes the top look it's way to FLAT and also makes it look like it slants to the rear, when if you look at the side windows they look to be right. Look at the BUBBLE above the rear 1/4 window and how low the crown is. If a person re-did the CROWN or BUBBLE on the back section of the roof it would look just like the Green car below. This would also raise the front of the rear window and make that area look better.
    Here is what I'm trying to say. Bob
  6. Mudslinger
    Mudslinger
    If you could get it cheap buy it and fix it.
    The rear window needed moved up about 5" to correct the drastic ski jump flat spot and the side back windows are what I called pinch chopped. The curves are removed and it also loses part of the flow. With a drastic chop like that it also needed the B pillars slanted.
    You can say 4" front and 5" to 6" in the back but if you cut the front posts 4" it will drop the windshield about 4 1/2" and then when you add the window gaskets you will lose another inch easy. On a sedan they look much much better cutting the rear window lose and sliding the whole thing forward 5" or more.
  7. torchmen49
    torchmen49
    BINGO!
    The problem with most radical chops is that the beltline length from front to back is left too long. To keep the flow you need to move that base of the rear backlight forward, which means fabbing a new sail panel. Replacing the stock curve at the end of the quarter windows and not letting them go to 'point' will also help with the effect.The verticle chop on my '49 is 6" at the 'B' pillar, and everything flows pretty good. By not moving the backlight forward, this leaves the upper edge of the rear backlight too low, and not allowing good progressional flow. The 'c' pillar section is then left with a definite 'flat' spot, and the rear of the roof loses what's left of the crown, creating the huge flat 'slope' to the trunk. Lastly, when viewing this style of chop from the rear, the backlight looks like someone stepped on it.
    The car in question is saveable. If you can get it for the right price, and you like the rest of the car, find a donor roof and make it right yourself. - Torch
  8. 50Fraud
    50Fraud
  9. Lunatic
    Lunatic
    from Carson,Ca.
    wow..any side shots?
  10. Francisco Plumbero
    Francisco Plumbero
    from il.
    Yeah its not that its too low, its that bump in the bondo, this has been a topic on this poor car, thats why the doh is there. The green and blue cars are just as low but they flow right , she needs some lovin, are you the one to give it to her?
  11. Mudslinger
    Mudslinger
    That actually looks like a decent car, just the roof needs some attention.
  12. wrong generation
    wrong generation
    from new jersey
    im one of the few that like it with that chop. :cool::D
  13. ScottV
    ScottV
    When there are no window openings at all, just metal ... that might be it !:p
  14. gimpyshotrods
    gimpyshotrods
    No side shot, but here's the rear. I think it is/was a Chevy, maybe. Not too sure. My head hurts.
  15. Lunatic
    Lunatic
    from Carson,Ca.
    WOW thanks...I have never seen one over done like that WOW
  16. elvi411
    elvi411
    3 1/4" or 4" is what i like in the front A's but eh what do i know.
  17. chaddilac
    chaddilac
    That one is awesome shoebox50.... know who owns it?? :D
