changing lug patterns on 68-72 chevy pick em ups
Discussion in 'The Hokey Ass Message Board' started by negativeMatt, Jan 19, 2005.
  1. is there a junkyard way to do this? currently a 6 lug, wanna 5 lugger!
  2. MattA
    MattA
    from Plano, tx
  3. briggs&strattonChev
    briggs&strattonChev
    simple wheel adaptors come to mind
  4. 80's model C-10 gives you 5 lug and disk.
    Pick-n-pull parts. Mine is a 72 going in a 64
    There are aftermarket axles if your attached to the Rearend.
  5. jerry
    jerry
    I think the change over year was '71 to 5 lug on the 1/2 ton with disc brakes. I know 72's have the 5 on 5 pattern.
    jerry
  6. [ QUOTE ]
    I think your right, my 71 3/4 ton has 8 lug, thats what I hate..talk about lack of wheel choices..
    jerry
    [/ QUOTE ]
  7. Only disc brake trucks have 5 on 5 till 73.
  8. radical56chevy
    radical56chevy
    easiest way is to get a set up off a 71.72 truck..
  9. Thats what I did, but the 72 axle's are different lengths from the 68 373 posi that I run now. [​IMG]
    So i'm still 6 lug out back, for now.
    Of course you can change the whole rearend, but I want to keep the good gears and posi in the narrower rear.
  10. sawzall
    sawzall
    [ QUOTE ]
    [/ QUOTE ]
    as was stated.. 71 72 trucks still have trailing arm rears and are 5 on 5 bolt circle..
  11. radical56chevy
    radical56chevy
    what you need is a set of axles from a 5 lug 70..same length as your 68
  12. I tried the 5 lug 72 axles and they don't fit.
    Are you saying 70's are different than 72's?
    I know there are aftermarket axles that run $300+ [​IMG]
    I'm a tight *******. [​IMG]
  13. radical56chevy
    radical56chevy
    [ QUOTE ]
    [/ QUOTE ]
    the 70's are shorter then the 72..
  14. Sweet, :thumbsup:
    Now I can get ole' Blue on 5 all the way around. [​IMG]
  15. RodZZilla
    RodZZilla
    70 is still 6 lug. 71 was the first yr for 5 lug. Take your axles to a machine shop and have them redrilled. $75 was the going rate the last I checked. Use the newer drums, or have yours drilled when they do the axles.
