Hot Rods 4 door A into a tub???
Discussion in 'The Hokey Ass Message Board' started by DirtyWoody28, Jul 2, 2010.
  1. DirtyWoody28
    DirtyWoody28
    What are your thoughts on this, I have never really been into the sedan to truck, tudor to tub, coupe to roadster etc. modifications. I think it kinda ruins the car. So how about a 4 door to a tub done with a roadster cowl? A friend of mine is thinking about it, I'm not so sure but I wanted to get some other opinions for him.
    thanks guys
  2. Boones
    Boones
    from Kent, Wa
    I think it could work. how about keeping the roll up windows and making a 4 dr convert with a removable center post like the 35-40 had. would allow you to keep the top of the doors with less modification and give the look as if Henry had done it from the factory, early protoype
    I have been thinking if I found a cheap 4 dr body i would go this route
  3. Fedcospeed
    Fedcospeed
    Look at my avatar.What I did was a 27 two door sedan cut behind doors and matched up to roadster cowl.Filled wheel wells .Had to pull in sides a bit but no big deal at all.Fabbed up new floor etc.I started out with three pieces of sedan and a cowl.Any sheet metal guy can do it.If you want I can send you a ton of build pics.This was my first ground up car.A little too low,but thats how I learned.Much more room than a T Bucket.Good luck and let me know about pics Jim F
  4. TERPU
    TERPU
    Sell the four door and buy a Tub. Alot easier and it'll look right.
    Tim
  5. DirtyWoody28
    DirtyWoody28
    I did some searching earlier, and the tudors can be done right if you roll the rear to match the curve of the body line.
