custom motor mounts
Discussion in 'The Hokey Ass Message Board' started by jtille, Apr 26, 2010.
  1. jtille
    jtille
    I would like to see some pictures of some custom motor mounts
  2. Kirk Hanning
    Kirk Hanning
    Here's something that is simple to make utilizing 2"x3" tubing. A flathead motor mount biscuit fits in it just fine.
    kiwijeff likes this.
  3. EnVoloNosFides
    EnVoloNosFides
    from Salem, OR
    Nice! Now I got an idea of what to do for mine!
    Thanks!
  4. Antny
    Antny
    from Noo Yawk
    That's real nice, Kirk! I dig. You make nice welds, too!
  5. Da Tinman
    Da Tinman
    my hurst style mount for 8ba and car pumps,,
    yes the bolts are in wrongside up, for some reason it was easier to put them in that way for the mockup.
    bct and kiwijeff like this.
  6. Mr48chev
    Not very showy but quite simple and clean. Seen on a little T bucket a couple of years ago.
  7. jtille
    jtille
  8. 53sled
    53sled
    from KCMO
  9. landseaandair
    landseaandair
    from phoenix
    Here's how I put a 215 Olds into my Model A. The crossmember has a slight V to clear the pan and the boxing plates have bolts welded to the back.
  10. Jalopy Jim
    Jalopy Jim
    here are the ones I built for my 54F100 with a 300 six
    bct likes this.
  11. jtille
    jtille
  12. Tin Can
    Tin Can
    The mounts I made for my 53
  13. 19Fordy
    19Fordy
    Here goes.
  14. chaddilac
    chaddilac
    Those pieces hooked to the hairpins run your shocks?
  15. ClutchDumpinDan
    ClutchDumpinDan
    SBC in a '61 Chevy pickup.
  16. ClutchDumpinDan
    ClutchDumpinDan
  17. ClutchDumpinDan
    ClutchDumpinDan
    322ci Nailhead going in my '27 T.
    The frame side of the motor mount, still needing trimmed...
  18. f'n newbie
    f'n newbie
    from colorado
    do you have any more pictures? Im doing the same with my 29 pickup and would love to know what steering and trans you used as well
  19. mgtstumpy
    mgtstumpy
    Rather than modify a Hurst style front mount to allow low mounted OT accessories I used 7/16" plate to move both mounts slightly to the rear due to twin dump Fentons. I also added a full length 7/16" x 7/16" reinforcing bar across the back of the plate to stop any deformation. In OEM position the exhausts dump directly onto engine tube so I had to use some lateral thinking. I also had to widen engine tube to compensate for additional width and machine a recess into plates to clear raised pads on rear of mounts. 20150711_122057.jpg 20130113_100002.jpg 2011-12-31 16.44.06.jpg 20130108_183104.jpg 20130108_183000.jpg lh HEADER TO MOUNT.jpg 20130108_182949.jpg
    Chucky likes this.
  20. jnaki
    jnaki
    Hello,
    Just about everything was custom machined by builder/designer, Atts Ono. The Willys was well do***ented in Popular Hot Rodding and was a show quality drag race car. We were fortunate enough to have him as a friend and part of our build/crew during our own 40 Willys race days. His beautiful, red Willys was finished in 1964.
    Thanks,
    Jnaki
    mad mikey likes this.
  21. mike bowling
    mike bowling
    3x3 angle ( from the s**** pile) and a pair of "hockey pucks"- quick, simple and CHEAP. DSCN1633.JPG
  22. Jmountainjr
    Jmountainjr
    Hurst style mount cut from 3/8" plate on band saw and using flathead style biscuit mounts:
  23. Fatbrosracing
    Fatbrosracing
    from Australia
    Similar to others posted but aluminium. IMG_6078.JPG IMG_6080.JPG IMG_6140.JPG
    mgtstumpy likes this.
  24. landseaandair
    landseaandair
    from phoenix
    Some pics in my build thread. http://www.jalopyjournal.com/forum/threads/yet-another-vicky-project.395833/ Olds didn't stay in the car but had a Turbo 350 with an adapter. Steering box and column is 1953-56 F100. All about the same but 1956 steering shaft is around 1 3/4" shorter due to the dished steering wheel.
  25. DDDenny
    Homebrewed mounts for my roadster.
    Brushed electroless nickel plated.
  26. D.N.D.
    D.N.D.
    Hey Denny what is that rod going down from the head maybe the alt belt tightner ?
    Nice tube mounts and plating shows a touch of cl*** too
    DND
  27. DDDenny
    Thanks DND, yes, it's part of the belt tensioning system.
    I had quite a lot of suspension pieces and other components nickel plated.
    More homebrewed stuff
