Stupid ? of the day
Discussion in 'The Hokey Ass Message Board' started by CayoRV, Jul 5, 2010.
  1. CayoRV
    CayoRV
    Got a nice looking small power rack and pinion from a friend of mine to try and use on an upcoming project. He said it was from a Chevy Chevette. I don't have any hoses or fittings and both of the ports for the pressure and return hoses are the same size and thread. Which is the pressure and which is the return? I'm sure it matters and the only thing I can tell ya further is that one is closer to the rack and the farther away or closer to the steering wheel. Anyone have a guess?
  2. Thumper
    Thumper
    It ain't from a Chevette. They had rack & pinion....but no power rack & pinion.
  3. Maybe it's from like a Citation, then. I've heard Autozone has a lot of shop manual stuff available online if you register on their site, maybe you can check there if no one knows here.
  4. d.reese
    d.reese
  5. 65stepside
    65stepside
    actually chevettes did come with power steering
    i had to swap to a manual rack when i put the 4.3 in my chevette
    i can probably dig up the rack and see which port is which
    if i can find it
  6. Thumper
    Thumper
    Hmmm.......what year did they offer them? Maybe one with the diesel engine to offset the extra front end weight. I've never seen a gas burner with PS.
  7. 65stepside
    65stepside
    mine is a 86
    my dads is a 87 both have power steering
    neither are diesel
    i think you had to order it if you wanted power steering
    i ve had 3 other ones they all had manual steering
    that being said
    thay are a pretty light duty unit i wouldn t put in a heavy car
  8. CayoRV
    CayoRV
    65stepside, can ya tell me which is which regarding the pressure and return lines? Greatly appreciate the help. Chuck
  9. '54Caddy
    '54Caddy
    hook it up and if the wheel shakes violently back and forth when you start the car you have it backwards. you have a 50/50 shot at getting it right the 1st time.
