1930 hudson
Discussion in 'The Hokey Ass Message Board' started by choptvan, Jul 5, 2010.
  1. Have to think you're going to have to make the deck lid. I can't see anyone in their right mind with a decent body parting with one, unless you can find one half-buried as a retaining wall somewhere, it's going to be faster to build one from scratch.
  2. choptvan
    choptvan
    I agree. But it is worth a try right?
  3. evil1
    evil1
    looking good
  4. I kind of thought that it might be a 29 body. I sorry to say, I cut one up for a race car years ago.:( I always liked the dual cowl vents.:cool:
  5. choptvan
    choptvan
    DAMN YOU! HA HA! jkjk I undersdtand. and those dual vents are why i really wanted the car in the first place.
  6. smarg
    smarg
    So that means what 4 banger right, straight 6? or what?
  7. truckncoupe
    truckncoupe
    very cool....I'll ask around here for any one with parts!:D
  8. Torkwrench
    Torkwrench
    If you want to keep it Hudson powered, the choice of engines should be easy....Twin H Power from an early 50's Hudson. Finding one may be kinda tough, though.
  9. choptvan
    choptvan
    If hudson made a 4 cylinder that i could get ahold of, I would LOVE to have that! Damn. Now you got me thinkin..... but most likely a six.
  10. choptvan
    choptvan
    thanks! Anything helps. Even dash knobs at this point.
    I would rather not. I have found those real hard to get. But I know what you mean.
  11. Midwest Rodder
    Midwest Rodder
    You are off to a great start, I don't understand what makes people shoot up a car when they come across it in the woods. Most of the time when I find a car when I am hunting it is full of holes.
  12. Streaker
    Streaker
    Choptvan,
    Hey it was great talking to you at VLV this year.
    Hope you find all the Hudson parts, I'll keep looking for you too.
    My 3-window is a '31.
    Lucky for me, I started with a better body than yours,
    but I admire your craftsmanship !
    Let me know if you need any other info.
    Dan
  13. smarg
    smarg
    Geez man, I like your Ideas.
    But a late 50's V8 would do justice to the chop top.
    A traditional ground pounding engine would do the trick for this one.
  14. orphanautomill
    orphanautomill
    If you want a Hudson engine, the 308 is the best option. This was the "Hornet" engine used from 51 on. The 262 can be a little cheaper and easier to find. That said, I've picked up (2) complete 308 blocks in the last few years for $100 ea. There are still quite a lot of bolt on options that will work on any of these blocks, and Twin H setups show up on E*ay quite often. Twin H will also fit on any of these blocks.
    Read this thread, very good info...
    http://www.jalopyjournal.com/forum/showthread.php?t=391692&highlight=hudson+308
    The body parts will be tough to find, check out the HET club and you can post an the cl***icar.com Hudson / streetrod sub forum.
    I would guess that your car had wood spokes, I can't think of a Hudson prior to 33 that I've seen with wire wheels, but I don't claim to be an expert.
    Looks like a cool build. Keep us posted.
  15. choptvan
    choptvan
    Right on! I had your car as my screen saver for a bit. Such a cool ride. I use it as inspiration for sure. Let me know what you find. And i appreciate it.
  16. hudson hot rod
    hudson hot rod
    For what it's worth, when I got my Hudson coupe I also got a 30 Hudson roadster body that I traded to a friend. There were a lot of original parts including the straight eight engine and a front axle and the rear diff that with as far as I can tell were the original wire wheels. All that could really be saved was a couple of the hub caps, the rest was left out in the weather so long it was just s**** iron, what a shame.
  17. choptvan
    choptvan
    Not tryig to go traditional. Just hudson.
  18. choptvan
    choptvan
    sounds like the way i found mine. Hell. Wasn't even good enough for s****. Thanks for the help on the wires. Would make her perfect for sure.
  19. ok going the other way... what about a V8 like you would find in the 55-57 hudsons.... amc 250 or packard 352
  20. choptvan
    choptvan
    I REALLY want a six. But i guess, depending on looks and aftermarket availability, i could do the v8.
  21. A 308 hornet motor with a wasp crank would give you a great de-stroked high rev motor. just a thought.
    my 29.
  22. choptvan
    choptvan
    now that is a cool pic!
  23. hudson hot rod
    hudson hot rod
    I was just going back over the thread and was looking at the difference in the wheels. I see Ramblur's Es*** has the wires and the green Hudson and the 32 have the wooden wheels but my Hudson came with the wires. Was there and option available back then for a choice of wires or wood or did they put on different wheels in different ***embly plants? Not that it matters I was just curious, anyone have any info?
  24. choptvan
    choptvan
    yeah. I didn't notice that. Good eye. Strange how the simple things get by you sometimes....
  25. HEMI32
    HEMI32
    choptvan ... I'm no expert, but I'd say your coupe is actually a 1931 Hudson ... just like Streaker's:
    Billetproof Car Show - Back To Billetproof
    Ever seen a hot rod Hudson? Dan Wathor's channeled '31 coupe is packed with a Super Red Ram Hemi with three deuces. Gray tuck 'n' roll and a custom dash dress up the inside. The outside features some nice 'striping on the firewall, deck, headlight housings, and grille shell. Santa Cruz Speed & Custom and the Crime Scene Choppers awarded it Best Orphan.
    Here's a side by side comparison of the visors on your coupe & Streaker's:
    click thumbnail to enlarge
    ... versus the '30 & '32 Hudson Visors:
    click thumbnails to enlarge
  26. Ramblur
    Ramblur
    Wood wheels standard,wire wheels an extra cost option. What I haven't
    figured out yet is the correct wires for an Es***. Mine came with
    drop center(one piece) rims on the front and split rings on the back.
    One old-timer told me the drop center were Es*** and the split-ring
    Hudson,but I haven't verified that.
  27. choptvan
    choptvan
    And things like that slipping is exactly what i was talkin about! Now how do you change the ***le of a thread??
  28. essexrat
    essexrat
    The body lines certainly match my 30 Es***...Somethings funny about the visor though..could be the difference between the Hudson and the Es*** or the difference between the coupe and the coach...either way...great choice in projects...I have a slough of Es***'s up here...unfortunatley, my spare doors are spoken for.
  29. essexrat
    essexrat
    Here's a couple pics of mine....I was told it was a 30 Es*** and by the design on the gauges and handles, it's confirmed..
  30. choptvan
    choptvan
    Everyone says that. I have a few but.... HA HA! jkjk
    that would be a fun car to build.
